0 Replies Latest reply on Feb 16, 2010 4:05 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 14201: Merging 4.x revision 14193 to trunk.
      Revision: 14201
      Revision: 14201
      Author:   egeorgie@adobe.com
      Date:     2010-02-16 16:05:29 -0800 (Tue, 16 Feb 2010)
      Log Message:
      Fix http://bugs.adobe.com/jira/browse/SDK-25334 When drag-copying an object between two s:Lists, the data object does not actually get copied
      Problems:
      1. We were copying the item, but throwing the copy away instead of adding it to the data provider
      QE notes: None
      Doc notes: None
      Bugs: SDK-25334
      Reviewer: Hans
      Tests run: checkintests, mustella tests/gumbo/component/ListDragDrop
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
      Property Changed:
          flex/sdk/trunk/
          flex/sdk/trunk/build.xml
