7 Replies Latest reply on Mar 9, 2010 3:51 PM by bringrags
    LayoutUtils.setAbsoluteLayout confusion
    jerryhamby Level 1
      Help me understand LayoutUtils.setAbsoluteLayout, it seems to work differently when
      you pass in metadata from a single element than from a SerialElement. The single version
      works just fine, the serial doesn't.
      SINGLE:
      TRACE: mMediaSizeChange pMediaElement.metadata =  [object Metadata]
      SERIAL:
      TRACE: mMediaSizeChange pMediaElement.metadata =  [object CompositeMetadata]
      I don't see any docs for CompositeMetadata inside org.osmf.metadata. I do see docs on Metadata.
      I run each item through some custom resize code and it gives me back an array of width, height, x, y
      I need for this to work for both single and serial.
      function mResizeAndMaintainAspectRatio(vOrgWidth:Number, vOrgHeight:Number, vTargetWidth:Number, vTargetHeight:Number):Array {
      LayoutUtils.setAbsoluteLayout( pMediaElement.metadata, vArray[0], vArray[1], vArray[2], vArray[3]);
        • 1. Re: LayoutUtils.setAbsoluteLayout confusion
          Edwin van Rijkom
          Hi Jerry,
          There should not be any difference between setting layout properties for atomic and composite elements. It is true that composites use a different metadata subclass (CompositeMetadata), but that should not have any influence on how the layout system works.
          I'm not exactly sure what problem you are running into: could you perhaps post a small sample app?
          (Just as a heads-up: the layout APIs have been changes quite a bit over the last two weeks. You'll find that the samples on the trunk no longer use LayoutUtils, but a class called LayoutProperties instead.)
          Cheers,
          Edwin
          • 2. Re: LayoutUtils.setAbsoluteLayout confusion
            jerryhamby Level 1
            I have attached a test file:
            1- The stage is set to 320x480
            2- make sure at least 2 of the images are larger size than the stage
            3- play each of the images separately through ImageElement
                to see proper results
            4- uncomment the serialElement code,  then run. You should see the
                 images are not resizing properly.
            5- watch the trace numbers when the SerialElement runs,
                the resize numbers are correct but LayoutUtils does not obey
                the correct numbers
            • 3. Re: LayoutUtils.setAbsoluteLayout confusion
              jerryhamby Level 1
              I have done some more testing and found another problem,
              I've added the additional code to the attached sample FLA.
              The problem is that the TimeEvent.COMPLETE event is not firing
              after I play a SerialElement with 3 videos.
              pPlayer.addEventListener(TimeEvent.COMPLETE,mComplete);
              The sample SerialElement containing 3 images,
              does fire correctly on the TimeEvent.COMPLETE event.
              It just has the other problem, I mentioned in the previous post.
              Now I'm more confused, I just don't know if it's a bug or my coding.
              Tested against Sprint 9.
              • 4. Re: LayoutUtils.setAbsoluteLayout confusion
                jerryhamby Level 1
                I can't seem to get any love from the OSMF team on this one,
                this is a MediaContainer issue and needs to be looked at.
                I have filed a bug:
                FM-451
                "LayoutUtils.setAbsoluteLayout does not obey correct numbers"
                • 5. Re: LayoutUtils.setAbsoluteLayout confusion
                  Edwin van Rijkom Level 2
                  Thank you for filing this as a bug. We're currently pretty much heads-down on getting the Sprint 10 release out of the door: appriciate your patience!
                  Cheers,
                  Edwin
                  • 6. Re: LayoutUtils.setAbsoluteLayout confusion
                    jerryhamby Level 1
                    FYI, looks like bug FM-451 is fixed in Sprint 10.
                    Little bit verbose, but I think a lot more control.
                    Works nicely on my SerialElement.
                    OLD CODE:
                    LayoutUtils.setAbsoluteLayout(pMediaElement.metadata, vArray[0], vArray[1], vArray[2], vArray[3]);
                    NEW CODE:
                    var vLayout:LayoutMetadata = new LayoutMetadata();
                    pMediaElement.addMetadata(LayoutMetadata.LAYOUT_NAMESPACE, vLayout);
                    vLayout.width=vArray[0];
                    vLayout.height=vArray[1];
                    vLayout.left=vArray[2];
                    vLayout.top=vArray[3];
                    • 7. Re: LayoutUtils.setAbsoluteLayout confusion
                      bringrags Level 4
                      That's great to hear.  I've marked the bug as fixed in the bug app.
