5 Replies Latest reply on Feb 17, 2010 2:20 AM by Vikram_S
    WebServices
    Shweta Gothe
      Hi ,
      In the schema , two operations are having same input and output messge.I am not able to that hit operation.Is it that Flex is not able to generate the stubs because of the namespace used in the schema ?
        • 1. Re: WebServices
          Yogi_ACE
          Not able to understand your question correctly.
          • 2. Re: WebServices
            Shweta Gothe Level 1
            <wsdl:operation name="UpdateST">
              <wsdl:input message="tns:SavedSTRequest" />
              <wsdl:output message="tns:GenericResponse" />
              <wsdl:fault name="Fault" message="tns:FaultMessage" />
              </wsdl:operation>
              <wsdl:operation name="CreateST">
              <wsdl:output message="tns:GR" />
              </wsdl:operation>
            I am able to hit CreateST but when I am trying to hit UpdateST I am getting 2032 error
            • 3. Re: WebServices
                </wsdl:operation>
                </wsdl:operation>
              • 4. Re: WebServices
                Yogi_ACE Level 2
                Shweta,
                #2032 error occurs when Flex is unable to find method. Check for Typo (exact method name).
                You can also use wireshark to figure out what is the input and output from method.
                Alternately, you can simply post html text to method by removing flex from the view.
                • 5. Re: WebServices
                  Vikram_S
                  can you try using fallowing code ?.
                  Write this in mxml <fx:Declarations>
                  <mx:WebService
                    id="service"
                    result="onResult(event)"
                    fault="onFault(event)"
                    wsdl="/*WSDL URL*\"/>
                  in Scirpt
                  function callService():void{
                       service.UpdateST.send(/*parameter*\);
