1 Reply Latest reply on Feb 17, 2010 8:55 AM by saisri2k2
    Resize Effekt for Items in Tilelist for MouseOver
    KlausFriese Level 1
      I like to have a soft resize for a TileList when the mouse is over an item. The ItemRenderer contains an image and and label. When the mouse is over the item the image should be enlarged and the label is invisible.
      That works fine without the resize effect, but with Resize effect and fast mouse movement some items did not change their size back to original size.
      This is my ItemRenderer:
      <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml"
      borderStyle="none" backgroundColor="#707682"
      width="200" height="200"
      mouseOver="doEnlarge(event)"
      mouseOut="doShrink(event)"
      horizontalScrollPolicy="off" verticalScrollPolicy="off">
      <mx:Script>
      <![CDATA[
      public function doEnlarge( e:MouseEvent ):void {
      trace( "large ");
      text.visible = false;
      image.width = 190;
      image.height = 190;
      public function doShrink( e:MouseEvent ):void {
      trace( "shrink ");
      image.width = 150;
      image.height = 150;
      text.visible = true;
      </mx:Script>
      <mx:Image id="image" x="10" y="10" width="150" height="150" source="image.png" scaleContent="true" autoLoad="true" resizeEffect="resizeMe"/>
      <mx:Label id="text" x="10" y="168" text="Text Text Text" width="150"/>
      <mx:Resize id="resizeMe" duration="200" />
      </mx:Canvas>
      Any tipps? And: is this a good way to get this kind of resize effect or are there better ways?
      thanks
      Klaus
        • 1. Re: Resize Effekt for Items in Tilelist for MouseOver
          saisri2k2 Level 4
          You have to register for the evnts in the
          override public function set data(value:Object):void{
               this.addEventListener(MouseEvent.MOUSE_OVER,doEnlarge);
               this.addEventListener(MouseEvent.MOUSE_OUT,doShrink)
          method(another method in the itemrenderer itself)... remove the event listeners from the canvas... if there is a way to get handle to the parent.. do an
          invalidateDisplayList(); (or) invalidateList(); calls after the resize/shrink method on the parent(obviously list)
          i would do
          public function resize(evt:MouseEvent):void{
                    ------your code --
               List(this.parent).invalidateList();
          Hope it wil help u
