4 Replies Latest reply on Feb 18, 2010 3:15 AM by Rodrigo Pena
    How I insert a SparkButton in a ns:Accordion?
    Rodrigo Pena
      Hi guys, i have some problem to insert a SparkButton in a ns:Accordion because I can not set a Skin. When I use mx:button all run fine, when I use s:button appears a error message about "skin error". I used NavigationContent in the Accordion, and my version of SDK of Flash Builder 4 is the build 13963.
      Someone have a problem like this?
        • 1. Re: How I insert a SparkButton in a ns:Accordion?
          FTQuest Level 3
          It's strange. Here is the code that works for me (beta2 14173):
             xmlns:mx="library://ns.adobe.com/flex/mx"
             minWidth="1024" minHeight="768">
          <fx:Script>
          <![CDATA[
          import spark.components.Button;
          private function addButton():void
          var secondBtn:Button = new Button();
          secondBtn.label = "I'm second";
          secondBtn.top= 20;
          secondBtn.left = 120;
          pnl.addElement(secondBtn);
          </fx:Script>
          <mx:Accordion x="10" y="10" width="240" >
          <s:NavigatorContent id="pnl" label="Incorporate s:Button" >
          <s:Button left="20" top="20" bottom="20" label="I'm fine" click="addButton()" />
          </s:NavigatorContent>
          </mx:Accordion>
          </s:Application>
          • 2. Re: How I insert a SparkButton in a ns:Accordion?
            Rodrigo Pena Level 1
            That's my code.
            <s:Application
            xmlns:mx="library://ns.adobe.com/flex/halo"
            minWidth="1024" minHeight="768" xmlns:mx1="library://ns.adobe.com/flex/mx">
            <fx:Declarations>
            <!-- Place non-visual elements (e.g., services, value objects) here -->
            </fx:Declarations>
            <mx1:Accordion x="69" y="65" width="200" height="200">
            <s:NavigatorContent label="Accordion Pane 1" width="100%" height="100%">
            <s:Button x="47" y="75" label="Button"/>
            <s:NavigatorContent label="Teste" width="100%" height="100%">
            <s:Button x="48" y="77" label="Button"/>
            <s:Button x="28" y="42" label="Button"/>
            </mx1:Accordion>
            </s:Application>
            The error message:
            VerifyError:  Error #1014: Class spark.skins::SparkSkin could not be found.
            • 3. Re: How I insert a SparkButton in a ns:Accordion?
              FTQuest Level 3
              This error - I believe - refers to your project settings rather than to particular application.
              Look at the instructions at the top of this forum window; specifically, 'merge into code'.
              • 4. Re: How I insert a SparkButton in a ns:Accordion?
                Thank you very much, worked fine!
