1 Reply Latest reply on Jun 6, 2008 3:25 AM by Noelbaland
    Passing Data from a Local variable
    trex007
      I have attached an onRelease event for a mc which increments the value of a variable by 1. The Whole functionality is inside another function.. Now hows it possible to make the data of the variable available globally, i.e if i want to use that data somewhere else in the same file.
        • 1. Re: Passing Data from a Local variable
          Noelbaland Level 1
          Hello there,
          Put your variable on the root timeline, like this
          var clipCount:Number = 0;
          function moveRight()
          clip_mc.onRelease= function()
          clipCount++;
          If you use a function that calls your variable from a different timeline (e.g. inside a movieclip or on a button), use _root to target it.
          _root.clipCount++;
          Hope that helps
