RH8.0.2 HTML.
Hi all, wondering if anyone has a fix for the horizontal scroll bar that popups up in my search pane for webhelp.
I've gone to great lengths to get my help in the right sized window with no horizontal scroll bars - they annoy me soooo much.
But now, and always I have noticed, they appear in the search pane when results are displayed. No matter how far i widen it they do not go away.
Is there some work aorund for this?
Thanks.
Nick
You can add a css rule overflow-x: auto; -- This should only show the scrollbars when the content is too small.
Add it in a style block in top of the culprit HTML-file. Let me know if that works.
Greet,
Willam
This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
Its not an html file thats the problem, its the actual search pane that displays results on the left hand side. The list of topics, and rank, this area no matter what always has a horizontal scroll bar.
perhaps there is somewhere to specify the column widths within his pane, like how you can set the width of the TOC
The search results are written in a HTML-file, are they not?
Checked in RH7, but I think it's the same in RH8:
In wfhdhtml.htm, the search windows is build using frames. Look for the frame that calls whfbody.htm. On the end of the line is the text scrolling='yes', set that to no.
If that doesn't work, I'll check in RH8 when I have the Chance.
Greet,
Willam
Thanks for clearing that up for me Willam, unfortunately its not playing nice.
If I set scrolling to no, then all scroll bars are gone. not ideal as I still want the vertical oens, I tried adding
<style type="text/css">
overflow-x: auto;
</style>
both after and before the <head> tag in the whfdhtml.htm page, but that didnt do anything either..any other tips?
thanks.
Doh... Didn't think of that...
Try adding the style block in whfbody.htm, just before the head tag. Setting it in the parent will not work for the child pages.
Greet,
Willam
still no joy....maybe just one of those things I have to live with.......
thanks for your help.
I'll check in RH8 when I have acces to that again.
Greet,
Willam
To remove the scroll bar, open whfbody.htm and go to line 3145. You see 110% and replace that with 100%.
Greet,
Willam
In my RoboHelp HTML RH8 project, I have the same problem. My whfbody.htm file in my WebHelp output has only 36 lines and no mention of 110%. What setting are you referring to? Thanks in advance.
Wrong file name... Try whfhost.js.
Greet,
Willam.
I found the offending 110% setting at Line 3151 in my whfhost.js file. When I changed it to 100%, the horizontal scroll bar went away. Thanks for your help!
