5 Replies Latest reply on Feb 22, 2010 2:08 PM by Sam Souhrada
    AdvancedDataGrid ItemRenderer Issue using code behind method
    Sam Souhrada
      I have been trying to get an itemrenderer to correctly work in an advanveddatagrid. I've used several itemrenderers in the past so this is pretty basic. I haven't however tried to attach to a grid that is inside a page using the code behind method. My issue is that the grid breaks if I try to put more than one visual component on the renderer. See the images below:
      Here is an example with a plain canvas itemrenderer:
      As you can see the scroll bar appears and everything looks normal.
      Here is the behavior if I add a label inside this component:
      The scroll bar disappears and I'm unable to close the itemrenderer correctly.
      Has anyone come across this issue before? Thanks for any help on this one!
        • 1. Re: AdvancedDataGrid ItemRenderer Issue using code behind method
          archemedia Level 4
          Can you post some code to test with?
          Dany
          • 2. Re: AdvancedDataGrid ItemRenderer Issue using code behind method
            Sam Souhrada Level 1
            I can't post all of the code since it's on a much larger page but hopefully this gives you an idea:
            <custom:ClientPlans xmlns:mx="http://www.adobe.com/2006/mxml" width="920" height="550" xmlns:flexlib="http://code.google.com/p/flexlib/"
                    fontFamily="HelveticaNeue Condensed" fontSize="11"
                    xmlns:components="components.*"
                    disabledColor="#FFFFFF"
                    themeColor="#FFFFFF"
                    horizontalScrollPolicy="off"
                    verticalScrollPolicy="off"
                    backgroundColor="#ffffff"
                    cornerRadius="10"
                    borderStyle="solid"
                    borderThickness="0"
                    horizontalCenter="0" verticalCenter="0" color="#808080">
            <mx:AdvancedDataGrid id="adgPlans" width="100%" height="497" selectionMode="singleRow" editable="false"
                                    color="#000000" fontSize="14" selectable="true"
                                    liveScrolling="false"
                                    showHeaders="false" variableRowHeight="true"
                                    disclosureOpenIcon="@Embed(source='/images/gridMinus.png')"
                                    disclosureClosedIcon="@Embed(source='/images/gridPlus.png')"
                                    folderOpenIcon="@Embed(source='/images/folderOpenIcon.png')"
                                    folderClosedIcon="@Embed(source='/images/folderclosedIcon.png')" borderThickness="1" borderStyle="solid">
                                      <mx:dataProvider>
                                             <mx:GroupingCollection id="gcGroup">
                                                    <mx:grouping>
                                                        <mx:Grouping>
                                                            <mx:GroupingField name="ClientName"/>
                                                        </mx:Grouping>
                                                    </mx:grouping>
                                             </mx:GroupingCollection>
                                      </mx:dataProvider>
                                    <mx:columns>
                                        <mx:AdvancedDataGridColumn id="clientNameColumn" dataField="clientName" headerText="Client" sortable="true" width="200" />
                                    </mx:columns>
                                    <mx:rendererProviders>
                                        <mx:AdvancedDataGridRendererProvider
                                            column="{clientNameColumn}"
                                            columnSpan="0"
                                            depth="2"
                                            renderer="components.subcomponents.clientRenderer3"/>
                                    </mx:rendererProviders>
                                </mx:AdvancedDataGrid>
            </custom:ClientPlans>
            Code-Behind:
            // ActionScript file
            package com.name
                    import mx.controls.AdvancedDataGrid;
                public class ClientPlans extends Canvas
                    public var adgPlans:AdvancedDataGrid;
                 public function ClientPlans ()
                        super();
                        this.addEventListener(FlexEvent.CREATION_COMPLETE, creationCompleteHandler);
                    private function creationCompleteHandler (event:FlexEvent):void
                          trace("cc");
            Item Renderer:
            <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml"
                width="100%" height="150" borderStyle="solid" borderThickness="2" borderColor="#56ACD1" cornerRadius="8"
                fontFamily="HelveticaNeue Condensed" color="#000000" backgroundColor="#FFFFFF" backgroundAlpha="1.0">
                <mx:Label text="Hello!?"/>
            </mx:Canvas>
            • 3. Re: AdvancedDataGrid ItemRenderer Issue using code behind method
              The only way I have gotten this to work is by setting the openDuration="0" ...
              Has anyone run into this before where the AdvancedDataGrid doesn't refresh properly if the openDuration is > 0 ?
              mx:AdvancedDataGrid id="adgPlans" width="100%" height="400" selectionMode="singleRow" editable="false"
                                      color="#000000" fontSize="14" selectable="true" openDuration="0" liveScrolling="false"
                                        <mx:dataProvider>
                                                      <mx:grouping>
                                                          <mx:Grouping>
                                                          </mx:Grouping>
                                                      </mx:grouping>
                                        </mx:dataProvider>
                                      <mx:columns>
                                      </mx:columns>
                                              columnIndex="0"
                                              columnSpan="0"
                                              depth="2"
                                              renderer="components.subcomponents.clientRenderer2"/>
              • 4. Re: AdvancedDataGrid ItemRenderer Issue using code behind method
                I've posted some test code on another thread I created which is a very similar issue. I've narrowed it down to all ItemRenderers for any object... not just ADGs.
                http://forums.adobe.com/thread/580862
                I appreciate the help!
                • 5. Re: AdvancedDataGrid ItemRenderer Issue using code behind method
                  addEventListener(Event.ENTER_FRAME, everyFrame);
                  commenting this out allowed the item renderers to display - Hope this helps out anyone stuck on this issue.
