4 Replies Latest reply on Feb 18, 2010 5:16 AM by K_Necelis
    Script error
    K_Necelis
      I am getting an error after doing some graphic updates to a Director 7.0 file. It is an interactive application that contains video -this error is within A Video Time Slider script.
      I am unsure why I am getting this error all of a sudden as I haven't modified this script at all - the text contained in the error message is the same exact text that appears in the old file version.
      Below is the error message I'm getting:
      Script error: Expected end of statement
      set memdefault = member (the membernum of member memref +1) of castlibnum?
      Any light anyone can shed on this would be greatly appreciated!!
      Thank you
        • 1. Re: Script error
          Sean_Wilson Adobe Community Professional
          Can you copy and paste a few lines before and after, and use the formatting tools under the >> menu (beside the smiley) to choose Syntax Highlighting -> Plain
          • 2. Re: Script error
            K_Necelis Level 1
            on getPropertyDescriptionList
              if the currentspritenum = 0 then
                set memdefault = 0
              else
                set memref = the member of sprite the currentspritenum
                set castlibnum = the castlibnum of memref
                set memdefault = member (the membernum of member memref + 1) of castlibnum
              end if
              set description = [:]
              addprop description, #VideoSprite, [#default: 1, #format:#integer,¬
            #comment: "Video Sprite:"]
            • 3. Re: Script error
              I don't know exactly what the problem is, but I notice a deprecated line continuation character (¬), generally "ancient" verbose Lingo, and the use of reserved keywords for variable names.
              Try:
                if (the currentspritenum = 0) then
                  memdefault = 0
                else
                  memref = sprite(the currentspritenum).member
                  memdefault = member(memref.memberNum + 1, libnum)
                end if
                description = [:]
                addprop description, #VideoSprite, [#default: 1, #format:#integer, #comment: "Video Sprite:"]
              • 4. Re: Script error
                K_Necelis Level 1
                THAT WORKED!! Thanks a million Sean!!
