• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Calling WebHelp Topics using Map IDs didn't work
New Here ,
Feb 17, 2010 Feb 17, 2010
Hi all,
Can anybody please tell me what is it that I am doing incorrect:
I created a sample web page and added the following to the head section:
<script type="text/javascript" language=JavaScript1.2 src="context-WebHelp/RoboHelp_CSH.js">
In the body, my link looked like this:
<A href='javascript:RH_ShowHelp(0,"C:\Program Files\...\Help\Infolinxweb_help.htm>Mainwindow", HH_Help_Context, 10)'>Help</a>
BTW: We have RH6
Sangeeta
Views
778
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Feb 18, 2010 Feb 18, 2010
Hi Sangeeta.
You'll find the correct syntax over at Peter Grainge's article on calling webhelp at:
http://www.grainge.org/pages/authoring/calling_webhelp/using_map_ids.htm
  • Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
  • Follow the RoboColum(n) on Twitter
Votes
Translate
Translate
Report
Report
New Here ,
Feb 19, 2010 Feb 19, 2010
I got the syntax from Peter's site only. I don't know why I can't make it work. The Help (or Bulk_Update I have given below in my syntax) link is coming fine on the web page. However, clicking on it just doesn't do anything.
Here is what i have in the header:
<script type="text/javascript" language=JavaScript1.2 src="C:\Program Files\Adobe\RoboHelp 6.0\CSH API\RoboHelp_CSH.js"></script>
Here is what i hace in the body:
<A HREF='javascript:RH_ShowHelp(0, "C:\Program Files\..\..\..\..\..\Infolinxweb_help.htm>Mainwindow", HH_HELP_CONTEXT, 10)'>Bulk_Update</a>
Notice, for the Windows path i have used "\" above, is it ok? I though it should be ok because that is how the path is recognized in Windows!
The map # "10" and the map Id "Bulk_Update" used as the parameter values above, are based on the map file. I didn't understand what exactly is "Mainwindow" used for in the syntax? I just copied it as it is. Can sombody please tell me that what is the mistake i am making which is preventing it to work?
Thanks for your help,
Sangeeta
Votes
Translate
Translate
Report
Report
LEGEND ,
Feb 22, 2010 Feb 22, 2010
There might be two things:
You're using \ instead of /. Replace the slashes.
You're using an absolute path to your harddrive. What happens if you use a relative path from the page you are calling the help, such as "../../Infolinxweb_help.htm"
Greet,
Willam
This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 24, 2010 Feb 24, 2010
LATEST
Thanks for your response Willam.
After I had given the presentation to the develpers of using either MapId’s or URL’s options for calling help, they selected the URL option.
However, I would still like to mention the things I did to make my MapId’s work:
  1. I had to bring the function in the source file itself somehow calling the function didn’t work for me.
  2. I had to change the backward slashes to forward slashes
  3. JavaScript is case sensitive and one parameter in the function (HH_HELP_CONTEXT) was causing problem because I had given in the lower case.
After correcting all the above it worked to the level that it was opening the Help but somehow it was not opening the correct page, the page whose MapId was given in the parameter. Instead, it was opening the start page of the help. I just could not figure that out.
I hope it is helpful to the people who are facing the same problem as I was!
Sangeeta
Message was edited by: Forum Moderator - Corrected spelling of Willam's name.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
