I'm working with IT to certify Captivate 3 - I need to
provide a test script. How cool would it be to capture opening
Captivate and performing basic functions using Captivate, then
publish to Word. Captivate will only allow one instance at a time.
I'm using Remote Desktop as well to test. Any thoughts to override
the one instance at a time rule?
There is
no prohibition
against opening multiple instances of Captivate on the same
desktop. The fact that you are not "local" (using Remote Desktop)
may be problematic however, and I don't know of a way around that
(if it doesn't work, that is ... I haven't personally tried it, so
am unsure why it wouldn't work for you) ...
Thanks for the reply.
Clarification - you can open up two instances of Captivate,
but you cannot be editing two movies at the same time...I wanted to
start recording and then demonstrate how to - well - start and
complete a recording. I was able to open an existing/demo movie and
perform some basic edit functions. I will need to augment my test
script with how to create a recording the old fashioned way.
Thing is this: Captivate is transparent when doing a record.
So you could record up to the moment you press record - but after
that you'd just be capturing a screen - as you would anyway. Do you
see what I mean?
You could mock it up nicely - it's a bit difficult to explain
though. Larry is right though - anything else you do with Captivate
Editing (which is where you add the magic anyway) can be captured
no problem.
Hi AJ - I needed a test script for our IT team to run when
validating the packaged instanced worked...so I wanted to use
captivate to create the script (click here, this happens, click
here, this happens...etc). I was able to open up an existing movie
to get most of the other functionality, but I could not record
creating a recording. Thanks!
The only way to do this would be to use a screen grab tool
such as
SnagIt to take screen shots of the New project options dialog etc.
Once you have captured these you can then just insert them as
images into your Adobe Captivate project.
And to expound on what fellow Adobe Community Expert Mark
offered, you could use the Highlight Box object in Captivate on
those slides to add the "Red Recording Rectangle" that would also
simulate the one you see in Captivate. Additionally, I've managed
to capture the "Camera Shutter Sound" effect Captivate produces
(it's actually embedded in the Captivate application and doesn't
exist as a sound clip). If you are interested in obtaining it, drop
me a line at captiv8r (at) kc (dot) rr (dot) com and I'll be happy
to send it your way. I recall it being difficult to obtain at the
time I needed it.
