3 Replies Latest reply on Feb 17, 2010 2:27 PM by kglad
    PHP, XML, AS2 - Login
    TheBrody
      I'm trying to make a login, I got my mysql database set up and everything. I'm trying to make the php file and XML file at the moment.
      I DON'T KNOW IF ANY OF THIS IS RIGHT - I'M NEW TO PHP and XML.
      I want it so that when you enter your username and password on flash, it checks it on the database. So I did:
      $user = $_POST[ 'username' ];
      $pass= $_POST[ 'password' ];
      $query = "SELECT * FROM users WHERE username = '$user' and password = '$pass'";
      So, I then made a thing so if it finds 1 row, then it changes a boolean from true or false.
      $result = mysql_query( $query ) or die( "didn't query" );
      $checklog = false;
      $num = mysql_num_rows( $result );
      if ( $num == 1 ) {
           $checklog = true;
      } else {
           $checklog = false;
      Now I'm trying to make the XML. I want it so if the $checklog is equal to true, then it says "Yes". Else, it says "No".
      if ( $checklog == true ) {
           echo "Ya";
      } else {
           echo "No";
      Thats all I got for now, Is there anything wrong with that?
        • 1. Re: PHP, XML, AS2 - Login
          that looks ok.  you can use:
          $checklog = false;
          if ( $num == 1 ) {
               $checklog = true;
          } else {
               $checklog = false;
          if ( $checklog) {
               echo "Ya";
          } else {
               echo "No";
          • 2. Re: PHP, XML, AS2 - Login
            TheBrody Level 1
            Okay, so for the flash, how would I make it login if the variable for checklog was true?
            Thats what I have so far.
            var theXML:XML = new XML();
            theXML.ignoreWhite = true;
            theXML.onLoad = function() {
            theXML.load("MYLINK");
            • 3. Re: PHP, XML, AS2 - Login
              is all the php you showed in one script?
