1 Reply Latest reply on Feb 18, 2010 10:20 AM by Michael Thornburgh
    Problem with net connection
    jananikrishna
      Hi everybody
      I am facing a problem with this code . the alert message  I get is NetConnection.Connect.Failed
      Please check this code and respond to me immediately as this is very urgent
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
      creationComplete="connect()">
          <mx:Script>
              <![CDATA[
              import flash.events.NetStatusEvent;
              import flash.net.NetConnection;
              import flash.net.NetStream;
              import mx.controls.Alert;
              private const StratusAddress:String = "rtmfp://stratus.adobe.com";
              private const DeveloperKey:String ="my developer key";
              private var nc : NetConnection;
              private function connect():void
                  nc = new NetConnection();
                  nc.addEventListener(NetStatusEvent.NET_STATUS,netConnectionHandler);
                  nc.connect(StratusAddress + DeveloperKey);
              private function netConnectionHandler(event:NetStatusEvent):void
                 Alert.show(event.info.code,"infocode");
                 Alert.show(nc.nearID,"peerid");
          </mx:Script>
      </mx:Application>
      Advance thanks
        • 1. Re: Problem with net connection
          Michael Thornburgh Adobe Employee
          two things (potentially) wrong with this code.  thing #1: there must be a "/" between "rtmfp://stratus.adobe.com" and your developer key.  #2: presumably you are actually using your real Stratus developer key and not literally "my developer key" for DeveloperKey.  if that's the case, then just add a trailing slash to the StratusAddress string.  or change the nc.connect line to read
             nc.connect(StratusAddress + "/" + DeveloperKey);
          -mike
