5 Replies Latest reply on Feb 21, 2010 4:48 AM by yu2009
    Write to XML
    Sherwette.Mansour
      Hi, I want to ask if there is anyway to write to xml file using a save button that does not include php?
        • 1. Re: Write to XML
          Madhav Subedi Level 4
          AFAIK Flex cannot do this
          • 2. Re: Write to XML
            Vikram_S Level 2
                 If you are using flash player with version 10.x then it is possible.
            var fileRef:FileReference = new FileReference();
            var data:String = "xml as string";
            fileRef.save(data,"test");
            I hope this will help you.
            Note: this will open save popup.
            Vikram
            • 3. Re: Write to XML
              Sherwette.Mansour Level 1
              Hi, I do need to install apache for the server right?
              • 4. Re: Write to XML
                Vikram_S Level 2
                HI,
                     I am not getting what you are doing.
                     If you are working with Flex for web application then it must require any back-end server(apache for php, tomcat for jsp, IIS) to serve your web      application over net.
                     for your post i.e. writting XML you don't require any backend server.
                Vikram
                • 5. Re: Write to XML
                  yu2009 Level 1
                  Vikram:
                  I guess your message is related to my post in the code gallery.  In the .mxml file, there exisits some piece of code like configxml (extra to be cleaned sometime when I am available).  It means it should get some variable values from its corresponding .xml (same name).  But in my .mxml, there is no need to get these variables.  Thanks.
                  Yours,
                  S
                  HI,
                  Vikram
