4 Replies Latest reply on Feb 18, 2010 2:25 PM by kenorrha18
    How can I remove a phantom picture?
    kenorrha18 Level 1
      Hi. I'm at a loss. I am working on a slide show. I removed a slide & put another in its place. Now I have the old picture sitting there like a phantom. I cannot see it, but it prevents the transition from sitting over 2 slides & when I put a transition over one slide, the phantom picture comes to the surface & moves over the new picture. weird. Can anyone tell me how to remove that, please? Linda
        • 1. Re: How can I remove a phantom picture?
          Assuming you built the slideshow in Premiere Elements, zoom in as close as possible to the spot on your timeline where the picture appears. (Zoom in with slider or by pressing the + key on your keyboard.)
          You may also be able to see the phantom slide in Sceneline view.
          • 2. Re: How can I remove a phantom picture?
            the_wine_snob Level 9
            I agree with Steve's suggestion to switch to the Timeline View Mode, and zoom in to the max. There is a slider above the Timeline, that will allow you to do a max zoom. I would hit the Home Key, to get to the beginning of the Timeline and then use the PageUp and PageDn keys to "step" through the Timeline, one Clip/Slide at a time. This process is for two reasons:
            1.) you will be looking for gaps in your Video Track
            2.) you will be looking for your "phantom" slide
            I would increase the size of the the vertical on the Timeline Panel, to see all of the Video Tracks, as your "phantom" slide could be on another Video Track besides Video Track 1.
            As you step through each Clip/Slide, notice the movement of the CTI (Current Time Indicator w/ the red Edit Line). It should jump from Clip to Clip. If it seems to hesitate, or "hiccup," there is either a gap, or something else there, causing it to hesitate. At that point, make sure to scroll the vertical on the Timeline, if you cannot see all Video Tracks, as a Clip (even a single Frame), might have gotten moved away from Video Track 1.
            Good luck, and good hunting,
            • 3. Re: How can I remove a phantom picture?
              Kodebuster Level 3
              If you can't find it on your Timeline by Zooming in as suggested, check the other Video Tracks, it's always possible that the Photo jumped up (or down
              to another Track, when you were moving things around).
              That seems to happen to me all the time, especially when rearranging the order of Photos on a Timeline...
              • 4. Re: How can I remove a phantom picture?
                kenorrha18 Level 1
                Steve,
                Thank you! You people who help so quickly have all helped to keep me sane.
                Thanks, Linda
