2 Replies Latest reply on Mar 29, 2010 1:34 AM by richtextformat
    FileStream fires no Events
    richtextformat Level 1
      I'm simply doing this:
      import org.alivepdf.pdf.PDF;
      private var _fs:FileStream;
      var printPDF:PDF = new PDF( Orientation.PORTRAIT, Unit.MM, ps );
      _fs = new FileStream();
      _fs.addEventListener(OutputProgressEvent.OUTPUT_PROGRESS, onOutput);
      _fs.addEventListener(ProgressEvent.PROGRESS, onProgress);
      _fs.addEventListener(Event.COMPLETE, onComplete);
      _fs.addEventListener(Event.ACTIVATE, onActivation);
      _fs.addEventListener(IOErrorEvent.IO_ERROR, onIOError);
      _fs.openAsync(file, FileMode.WRITE);
      var bytes:ByteArray = printPDF.save(Method.LOCAL);
      The only event that is firing is OutputProgressEvent.OUTPUT_PROGRESS, which is giving me [once]:
      private function onOutput (event:OutputProgressEvent):void
           trace(event.bytesPending, event.bytesTotal);
      trace output here being:
      0 / 229779
      Nothing else fires, meaning I can't close the FileStream session, meaning starting a second causes this error:
      Error #2041, Only one file browsing session may be performed at a time
      Been struggling for days. Going mental. Any ideas?
        • 1. Re: FileStream fires no Events
             I am facing similar problem with my applcation. Did u got the solution? Also I want  to know
          How to add page numbers to the generated PDF, if it has multiple paes.
          Also when I am using Tab navigator,  which is based on ViewStack and my creation policy is auto. When I am not selecting the other tabs, they are not created and so how can I generate their data in PDF?
          Pleae let me know if you knoe anything about these. I am using   ALivePDF 0.1.5
          • 2. Re: FileStream fires no Events
            hello fresher4flex
            no, but i did manage to work around it by enclosing problematic FileStream code snippets in try/catch statements. Now I can create multiple pdfs all day.
            I was also using AlivePDF
