1 Reply Latest reply on Feb 19, 2010 11:55 PM by FlexPrashant
    Webservice Random Faults
    amadas Level 1
      We have been encountering random SOAP Faults in our application. Definitely something is going wrong.
      We have a CF implementation for webservices (using coldspring) consumed by the flex application.
      The end users are randomly encountering Fault events. We are using FLEX SDK 3.5
      Here are the details -
      faultCode = DecodingError
      faultString = SOAP Response cannot be decoded. Raw response: null
      faultDetail = null
      The same webservice call works 99% of the time. Randomly we encounter some faults.
      Monitoring the network SOAP packets using Fiddler, we get HTTP 200 OK response without any error.
      We enabled Flash Debug logging with all events to be logegd into flashLog.txt and we found that the fault is generated internal to the framework -
      2/17/2010 09:28:11.935 [INFO] mx.rpc.soap.Operation Creating SOAP Operation for getCacheUpdates
      2/17/2010 09:28:11.935 [DEBUG] mx.rpc.soap.Operation Invoking SOAP operation getCacheUpdates
      2/17/2010 09:28:11.935 [DEBUG] mx.rpc.soap.SOAPEncoder Encoding SOAP request envelope
      2/17/2010 09:28:11.945 [DEBUG] mx.rpc.soap.SOAPEncoder Encoding SOAP request body
      2/17/2010 09:28:11.945 [INFO] mx.messaging.Producer 'E62FB659-260E-FDD0-479B-DC8AAF12EE52' producer sending message 'FACB3D46-5745-E0B7-4F3C-DC8B26A9872C'
      2/17/2010 09:28:11.945 [DEBUG] mx.messaging.Channel 'direct_http_channel' channel sending message:
      (mx.messaging.messages::SOAPMessage)#0
        body = "<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
        <SOAP-ENV:Body SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
          <intf:getCacheUpdates xmlns:intf="http://webservices.com.webservices">
            <adex xsi:type="xsd:string">&lt;adex&gt;
        &lt;header&gt;
          &lt;status&gt;true&lt;/status&gt;
          &lt;operatorToken/&gt;
          &lt;terminalToken/&gt;
        &lt;/header&gt;
        &lt;body&gt;
          &lt;data name="cacheStatus" dataType="object"&gt;&lt;![CDATA[{"park":"02/16/2010 06:02:07 PM","parkPass":"01/01/2000 12:00:00 AM","country":"02/16/2010 06:02:07 PM","site":"02/16/2010 06:02:07 PM","loop":"02/16/2010 06:02:07 PM","ticketType":"02/16/2010 06:02:07 PM","discount":"02/16/2010 06:02:07 PM","location":"02/16/2010 06:02:07 PM","equipment":"02/16/2010 06:02:07 PM","campground":"02/17/2010 09:28:11 AM","asset":"01/01/2000 12:00:00 AM","state":"02/16/2010 06:02:07 PM","retail":"02/16/2010 06:02:07 PM"}]]&gt;&lt;/data&gt;
          &lt;data name="parkId" dataType="numeric"&gt;&lt;![CDATA[511]]&gt;&lt;/data&gt;
          &lt;data name="locationId" dataType="numeric"&gt;&lt;![CDATA[6558]]&gt;&lt;/data&gt;
        &lt;/body&gt;
      &lt;/adex&gt;</adex>
          </intf:getCacheUpdates>
        </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>"
        clientId = "DirectHTTPChannel0"
        contentType = "text/xml; charset=utf-8"
        destination = "DefaultHTTP"
        headers = (Object)#1
        httpHeaders = (Object)#2
          SOAPAction = """"
        messageId = "FACB3D46-5745-E0B7-4F3C-DC8B26A9872C"
        method = "POST"
        recordHeaders = false
        timestamp = 0
        timeToLive = 0
        url = "http://xyz/webservices/com/webservices/CachingWebServices.cfc"
      2/17/2010 09:28:12.505 [INFO] mx.messaging.Producer 'E62FB659-260E-FDD0-479B-DC8AAF12EE52' producer acknowledge of 'FACB3D46-5745-E0B7-4F3C-DC8B26A9872C'.
      2/17/2010 09:28:12.505 [ERROR] mx.messaging.Producer 'E62FB659-260E-FDD0-479B-DC8AAF12EE52' producer fault for 'FACB3D46-5745-E0B7-4F3C-DC8B26A9872C'.
      Its actually getting generated from Line 710 of mx.messaging.MessageAgent.as
      Here is the RAW Response in the fiddler (HTTP 200 OK)
      HTTP/1.1 200 OK
      Connection: close
      Date: Wed, 17 Feb 2010 15:22:46 GMT
      Content-Type: text/xml; charset=utf-8
      Server: Microsoft-IIS/6.0
      PICS-Label: (PICS-1.0 "http://www.rsac.org/ratingsv01.html" l on "2009.11.13T12:51-0600" exp "2015.11.13T12:00-0600" r (v 0 s 0 n 0 l 0))
      X-Powered-By: ASP.NET
      Vary: Accept-Encoding
      Set-Cookie: Coyote-2-a0305b5=a030548:0; path=/
      Content-Length: 1345
      <?xml version="1.0" encoding="utf-8"?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
      <soapenv:Body>
        <ns1:getCacheUpdatesResponse soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns1="http://webservices.com.webservices">
         <getCacheUpdatesReturn xsi:type="soapenc:string" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/">&lt;?xml version=&quot;1.0&quot; encoding=&quot;UTF-8&quot;?&gt;
      &lt;adex&gt;&lt;header&gt;&lt;status&gt;true&lt;/status&gt;&lt;operatorToken&gt;&lt;/opera torToken&gt;&lt;terminalToken&gt;&lt;/terminalToken&gt;&lt;/header&gt;&lt;body&gt;&lt;data datatype=&quot;query&quot; name=&quot;cacheUpdates&quot;&gt;&lt;![CDATA[{&quot;COLUMNS&quot;:[&quot;CACHENAME&quot;, &quot;GETUPDATE&quot;],&quot;DATA&quot;:[[&quot;park&quot;,0],[&quot;location&quot;,0],[&q uot;campground&quot;,0],[&quot;loop&quot;,0],[&quot;state&quot;,0],[&quot;asset&quot;,0],[ &quot;country&quot;,0],[&quot;site&quot;,0],[&quot;ticketType&quot;,194],[&quot;parkPass&q uot;,18631],[&quot;equipment&quot;,0],[&quot;discount&quot;,0],[&quot;retail&quot;,1.0]]}] ]&gt;&lt;/data&gt;&lt;/body&gt;&lt;/adex&gt;</getCacheUpdatesReturn>
        </ns1:getCacheUpdatesResponse>
      </soapenv:Body>
      </soapenv:Envelope>
      Ideally this is how the packets should go through (for another operation which goes through fine )-
      2/17/2010 09:28:10.523 [INFO] mx.rpc.soap.Operation Creating SOAP Operation for getSystemDateTime
      2/17/2010 09:28:10.523 [DEBUG] mx.rpc.soap.Operation Invoking SOAP operation getSystemDateTime
      2/17/2010 09:28:10.523 [DEBUG] mx.rpc.soap.SOAPEncoder Encoding SOAP request envelope
      2/17/2010 09:28:10.523 [DEBUG] mx.rpc.soap.SOAPEncoder Encoding SOAP request body
      2/17/2010 09:28:10.523 [INFO] mx.messaging.Producer 'A9887317-57D3-3B38-74A0-DC8AA2A2D59C' producer sending message '55C1476D-A54B-11F2-512C-DC8B211B8D6E'
      2/17/2010 09:28:10.533 [DEBUG] mx.messaging.Channel 'direct_http_channel' channel sending message:
          <intf:getSystemDateTime xmlns:intf="http://webservices.com.webservices"/>
        </SOAP-ENV:Body>
          SOAPAction = """"
        messageId = "55C1476D-A54B-11F2-512C-DC8B211B8D6E"
        method = "POST"
        timestamp = 0
        timeToLive = 0
        url = "http://xyz/webservices/com/webservices/SecurityWebServices.cfc"
      2/17/2010 09:28:11.534 [INFO] mx.messaging.Producer 'A9887317-57D3-3B38-74A0-DC8AA2A2D59C' producer acknowledge of '55C1476D-A54B-11F2-512C-DC8B211B8D6E'.
      2/17/2010 09:28:11.534 [INFO] mx.rpc.soap.SOAPDecoder Decoding SOAP response
      2/17/2010 09:28:11.544 [DEBUG] mx.rpc.soap.SOAPDecoder Encoded SOAP response <?xml version="1.0" encoding="utf-8"?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
      <soapenv:Body>
        <ns1:getSystemDateTimeResponse soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns1="http://webservices.com.webservices">
         <getSystemDateTimeReturn xsi:type="soapenc:string" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/">&lt;?xml version=&quot;1.0&quot; encoding=&quot;UTF-8&quot;?&gt;
      &lt;adex&gt;&lt;header&gt;&lt;status&gt;true&lt;/status&gt;&lt;operatorToken&gt;&lt;/opera torToken&gt;&lt;terminalToken&gt;&lt;/terminalToken&gt;&lt;/header&gt;&lt;body&gt;&lt;data datatype=&quot;date&quot; name=&quot;CurrentDateTime&quot;&gt;&lt;![CDATA[February 17, 2010 09:02:16]]&gt;&lt;/data&gt;&lt;/body&gt;&lt;/adex&gt;</getSystemDateTimeReturn>
        </ns1:getSystemDateTimeResponse>
      </soapenv:Body>
      </soapenv:Envelope>
      2/17/2010 09:28:11.554 [DEBUG] mx.rpc.soap.SOAPDecoder Decoding SOAP response envelope
      2/17/2010 09:28:11.554 [DEBUG] mx.rpc.soap.SOAPDecoder Decoding SOAP response body
      2/17/2010 09:28:11.554 [INFO] mx.rpc.soap.SOAPDecoder Decoded SOAP response into result [20 millis]
      Before i dig into checking out Flex SDK framework to build / compile / put breakpoints and debug, I just wanted to know if anyone has an outright solution for a similar problem encountered before.
      Arun
        • 1. Re: Webservice Random Faults
          FlexPrashant
          Hi I am also facing a problem I want to send a string to my sap webservice into the following format
          <DATA><STRUCTURE VAL="FLASH"><VALUEPART VAL="40100"></VALUEPART></STRUCTURE><STRUCTURE VAL="FLEX"><VALUEPART VAL="2000"></VALUEPART></STRUCTURE></DATA>
          But whenever I am sending this string to my webservice in webservice it is reading this data like
          &amp;lt;DATA&gt;&amp;lt;STRUCTURE VAL="FLASH"&gt;&amp;lt;VALUEPART VAL="40100"&gt;&amp;lt;/VALUEPART&gt;&amp;lt;/STRUCTURE&gt;&amp;lt;STRUCTURE VAL="FLEX"&gt;&amp;lt;VALUEPART VAL="2000"&gt;&amp;lt;/VALUEPART&gt;&amp;lt;/STRUCTURE&gt;&amp;lt;/DATA&gt;
          Please help me to solve the problem .
