0 Replies Latest reply on Feb 18, 2010 8:53 AM by Paul Reilly
    [svn:fx-4.x] 14245: * Fixed inactive incremental compilation issue where library changes
    Paul Reilly Level 1
      Revision: 14245
      Revision: 14245
      Author:   preilly@adobe.com
      Date:     2010-02-18 08:53:00 -0800 (Thu, 18 Feb 2010)
      Log Message:
      • Fixed inactive incremental compilation issue where library changes
        were not causing application recompilation.
      QE notes: We should add a JUnit OEM API test for this scenario.
      Doc notes:
      Bugs: SDK-25513
      Reviewer: Pete F.
      Tests run: checkintests
      Is noteworthy for integration: yes, affects active incremental
                                     compilation from FB.
      Code-level description of changes:
        Modified the loadCompilationUnits() used by
        flex2.tools.oem.Application to pass the "sources" and "units" args
        down, so that the PersistenceStore can populate them.  This is
        necessary to get OEMUtil.isRecompilationNeeded() called in
        Application.recompile().
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25513
      Modified Paths:
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
