33 Replies Latest reply on Mar 3, 2010 1:11 PM by darent5556
    Problem with 9.3 Reader when opening files from internet
    Can_Ada
      I keep receiving the message 'There is a problem with Adobe/Acrobat Reader.  Please exit Adobe Acrobat/Reader and try again' when trying to open come files on the internet.  I am able to open files from my hard drive and some files from the internet.  I have uninstalled and re-installed Reader, but get same result.  Any ideas?
        • 1. Re: Problem with 9.3 Reader when opening files from internet
          bobmakemoney
          Same problem here on my work PC no matter what I or IT support tried we still couldn't get it to work.
          In the end we were just forced to revert to the previous V8.x.  Sorry thats probably not much help to you.
          Strangely my home PC is fine with V9.3 but then again its not got all the corporate controls and policies inflicted on my work PC.
          • 2. Re: Problem with 9.3 Reader when opening files from internet
            pspar
            I am having the exact same problem.  I can open PDFs in Adobe Reader (AR) version 9.3 without any problem when opening directly with AR.  However, when on some webpages, I click to open the PDF and it just spins seemingly forever, and then I get the following message:  "There is a problem With Adobe Acrobat/Reader. Please exit Adove Acrobat/Reader and try again.  OK"  (see attachment)
            I have unistalled the program to include Adobe Air, restarted my machine, downloaded the program again, and reinstalled.  I still get the same results.
            This is very frustrating.  In my job we are constantly creating PDFs and uploading them to our webpage.  I create a PDF, upload it, and then cannot open it.  I desperately need AR to do my job.
            I am using Windows 7 and running Internet Explorer 8.
            Is the only solution to install an older version (8) of AR?  Help!
            • 3. Re: Problem with 9.3 Reader when opening files from internet
              Ubuntu17
              I can not view embedded PDF files with 9.3. If I install 8.2 embedded PDF files work just fine from within a webpage. Any ideas why this is happenign?????
              • 4. Re: Problem with 9.3 Reader when opening files from internet
                pspar Level 1
                Have discovered the solution to this problem!!!  Go to this link:
                http://www.thetechherald.com/article.php/201007/5257/Adobe-offers-flawed-version-of-Reader -after-update
                Steve Ragan's article in The Tech Herald gives you the correct information.
                Essentially, you must install  Acrobat Reader (AR) version 9.3 and then IMMEDIATELY open  AR and Check for Updates in the Help Menu.  Your should get an offer to update to:  Adobe Reader 9.3.1 (CPSID_50570).  Download and install this update.
                I did so and now am able to easily and very quickly open any PDFs from within the website where I am working.
                Success at last!!  Hurrah!
                Enjoy,
                pspar
                • 5. Re: Problem with 9.3 Reader when opening files from internet
                  pspar Level 1
                  I have discovered the solution and posted it to the Adobe Forum.
                  I have tested the solution and IT WORKS!!!
                  Adobe Reader is NOT the solution as it has to many critical
                  vulnerabilities.
                  Read the information I provide at the link in the forum.  It explains
                  everything.
                  Cheers,
                  pspar
                  • 6. Re: Problem with 9.3 Reader when opening files from internet
                    pspar Level 1
                    I meant to say, Adobe Reader vers. 8.2 is NOT the solution.  Regrets...
                    • 7. Re: Problem with 9.3 Reader when opening files from internet
                      too green Level 1
                      I am running Adobe Reader v9.3.1 (not v9.3) on a Windows 7 64 bit OS.
                      I have been having the same problems opening pdf files as described above.
                      The following two solutions work for me:
                      1.  disable the Google tool bar.
                      or
                      2.  Open Adobe Reader,
                                  go to edit menu,
                                  under Preferences
                                  go to Internet, uncheck "Display pdf in browser"
                      The pdf files then open, but not in the browser
                      Take your choice.  Either works for me.
                      too green (maybe I am not as "green" as I thought)
                      • 8. Re: Problem with 9.3 Reader when opening files from internet
                        Ubuntu17 Level 1
                        I have tried both of your suggestions and still I can not view embedded PDF files in webpages. This is getting very frustrating, I have no idea why Reader 8 will work but 9 will not. Is there a posibility of a group policy or firewall setting that might be causing the problem? I know i might be grasping at straws here but I will try any suggestions.
                        • 9. Re: Problem with 9.3 Reader when opening files from internet
                          too green Level 1
                          I'm sorry it won't work for ytou.  By the way I only have trouble with IE 8.  Firefox 3.5.7 opens the offending pdf's without a problem.
                          Too Green
                          • 10. Re: Problem with 9.3 Reader when opening files from internet
                            Newtonej
                            I am also having this issue, most pcs in the office are affected. as far as i can tell its only effecting pdf files larger then around 450kb anything smaller opens fine. other pdf viewers like foxit will open all files fine. ive tried. im trying this on a fresh installed of windows 7 64bit, and clean install of adobe 9.3, and then upgraded to 9.3.1
                            • 11. Re: Problem with 9.3 Reader when opening files from internet
                              too green Level 1
                              Well, my problem has gone away.  I now am able to open all the pdf files on our web site with the Google tool bar enabled and pdf reader v 9.3.1 set to "display pdf in browser."   My OS is Windows 7 professional 64 bit.  Incidently when I downloaded AdobeReader I got v9.3.1 without having to get any updates.
                              Several days ago I had to either disable the Google tool bar or set Adobe Reader to not display pdf files in browser. As far as I can tell I have not done anything else that would change the way pdf files open.
                              By the way file size did not seem to be the problem.  The largest of the files (144 KB) always opened without a problem.  The smaller files (between 28 - 138 KB) were the problem.
                              I am afraid to believe the problem opening pdf files won't return.
                              • 12. Re: Problem with 9.3 Reader when opening files from internet
                                Comcast Web Page
                                Any time I try to open a file with thi program I am always unable to do it, but I don't really know where the problem is, Please if you could give me an idea I would appreciate that.
                                Thank you
                                Marcelus
                                • 13. Re: Problem with 9.3 Reader when opening files from internet
                                  Jan Thyer
                                  I am having the same problem. I'm on Windows XP Home Edition.  Everything was hunky-dory with 8 but when I tried to open something on Adobe's web site it told me I had to upgrade to 9 to be able to view what they had posted. I did so and now I can't open anything on the web. Things NOT on web are okay but it just hangs if I try to open PDF in Mozilla Firefox. Haven't tried Internet Explorer yet.
                                  I tried solutions mentioned previously (i.e., updates, etc.) but they don't work. I still have Reader 8 installed and it asked me when it was installing 9 if I wnated to continue primarily opening PDFs in 8 or in 9 and I chose 8. It told me I could change that whenever I wanted to but when I tried I couldn't figure out how to do that.
                                  • 14. Re: Problem with 9.3 Reader when opening files from internet
                                    too green Level 1
                                    Did you try this as mentioned in my Feb. 19 post?
                                    Open Adobe Reader,
                                                go to edit menu,
                                                under Preferences
                                    As I mentiioned I have returned all the settings on my browser and in AdobeReader to their original settings and I now can open pdf files without a problem.  I did not download any updates to explain why the problem went away.
                                    • 15. Re: Problem with 9.3 Reader when opening files from internet
                                      Ubuntu17 Level 1
                                      Yes I have tried that and still nothing. However I did get my
                                      network admin to look into it and we found that the page was sending a "text/html" content type when it should be sending a "application/PDF" content type. I have contacted the website and they are looking into it. Hopefully this is the problem because I have tried everything else Adobe suggested in this article http://kb2.adobe.com/cps/328/328233.html
                                      • 16. Re: Problem with 9.3 Reader when opening files from internet
                                        Can_Ada Level 1
                                        My issue has been resolved (maybe) by following the recommendations of too_green.  I have now reset my preferences and Google tool bar back to the original settings.  Reader seems to be working!  My thanks to all!
                                        • 17. Re: Problem with 9.3 Reader when opening files from internet
                                          Panozgrl
                                          Unfortunately for me the resolution of setting Reader as a helper program with IE is not an option.  My users are required to use webpages that require the ability to open PDF files within the browser.  None of my users has the Google toolbar installed so that is not the problem either.  Any other suggestions?  I believe this has to be a problem caused by Microsoft's last patch release because it worked fine before that.
                                          • 18. Re: Problem with 9.3 Reader when opening files from internet
                                            oldschool10
                                            I don't know which one solved my problem. Did the following :
                                            1) Installed the updated for Adobe Reader 9.0, current version is 9.3.0
                                            2) Uninstall google tool bar
                                            3)Opned My computer -> Tools -> Folder Options -> File Types, look for Extensions PDF
                                            Select that row, then click "change" button. Then you should see a window "Open with", click the browse button at the bottom
                                            Select the file Program Files ->Adobe -> Reader 9.0 -> Reader ->  AcroRd32.exe.
                                            I belive the 3rd step sloved the problem because after the first two steps, the problem did exists.
                                            By the way I am on WinXp, IE 8. I didn't have this issue in firefox 3.5 or Safari.
                                            • 19. Re: Problem with 9.3 Reader when opening files from internet
                                              too green Level 1
                                              Interesting.  Actually the latest version of AdobeReader for my OS (Windows 7 64 bit) is 9.3.1. This version downloaded without needing any updating.
                                              I have discovered that the only part of the Google tool bar that I need to disable is the translation feature.
                                                          On the Google tool bar
        click on the options icon (a wrench)
        go to Tools
        scroll down to the bottom
        uncheck Translate
                                              I just tried installing the Google tool bar for Firefox and left all the default settings as set.  I can still open all the pdf file on our web site.  I have come to the conclusion that the problem for me is with Windows 7, IE 8, AdobeReader, and the Google Tool bar translation feature.
                                              As an additional note.  I am web administrator for a web site that made use of the Google translation widget.  It worked until the sever was changed for the web site.  Then all sorts of strange things happened with my menu listings.  We had to remove the widget and make changes in the code to get rid of the offending problems.
                                              • 20. Re: Problem with 9.3 Reader when opening files from internet
                                                ftrades
                                                Have the same problem with Aobe Reader 9.3.1 in Windows 7 32-bit with IE 8 and it just started this week  .. suspect latest Windows Updates created
                                                a conflict somewhere.  There is no problem in Firefox.
                                                Two workarounds for IE 8 users, both have been mentioned,
                                                1.  Uninstall Google Toolbar in IE 8 - can open pdf files in browser window
                                                2.  Set Adobe Reader Preferences to NOT display PDF in browser window (uncheck box in Preferences) - can open PDF's with Google Toolbar installed, but not in a browser window.
                                                Alternatively, use Firefox for a browser.  Like I said, all was well before this week in IE 8  and all remains well using Firefox as a browser with Google Toolbar installed.
                                                EB
                                                • 21. Re: Problem with 9.3 Reader when opening files from internet
                                                  Panozgrl Level 1
                                                  I don't think this problem has much to do with the Google toolbar because I have the toolbar installed along with IE8 and I can sit and open PDF docs all day long and not have one problem.  And setting Reader as a helper application is an unacceptable solution for my users.
                                                  As I said in my previous post I believe this has to do with an update Microsoft did during the last patch Tuesday.
                                                  • 22. Re: Problem with 9.3 Reader when opening files from internet
                                                    Ubuntu17 Level 1
                                                    For my problem I can open up the PDF if I search through the source code and find the path to the PDF. I can then paste that into the address bar and the PDF opens just fine. It has to be the way the site has coded their embedded PDF files for them not to open because every other PDF file that is not embedded opens just fine.
                                                    • 23. Re: Problem with 9.3 Reader when opening files from internet
                                                      ftrades Level 1
                                                      All I can tell you is I've proven my hopefully temporary "workaround" with both fixes.  In IE 8 on a Win 7 32-bit platform using Adobe Reader 9.3.1 I cannot open PDF files in a browser window with Google Toolbar [Version: 6.4.1321.1732/en (GGLL)  Notifier Version: 5.5.4723.1820]  installed and running.  I can open PDF files from weblinks directly with Adobe Reader set via the preferences to NOT open in a browser window (opens in an Acrobat Reader window),  and separately I can open in a browser Window if I uninstall Google Toolbar.  The combination (open PDF's in a browser window with IE8 that is running Google Toolbar) won't work on my platform.  In Firefox 3.6 there is no problem or conflict - everything works as it should.
                                                      The problem just started last Thursday.  Before that there was no problem.  So I too suspect either a Windows Update or a Google Toolbar update create the problem.  Tomorrow is update Tuesday - maybe we get lucky.
                                                      • 24. Re: Problem with 9.3 Reader when opening files from internet
                                                        oldschool10 Level 1
                                                        I'll  take back my previous post. As too green said, for me it was google toolbar and it's translate function. Un checking that one solved my issue.
                                                        • 25. Re: Problem with 9.3 Reader when opening files from internet
                                                          ftrades Level 1
                                                          " ....As too green said, for me it was google toolbar and it's translate function. Un checking that one solved my issue. "
                                                          I had missed that detail.  That fixed it for me too.  Many thanks!
                                                          EB
                                                          • 26. Re: Problem with 9.3 Reader when opening files from internet
                                                            Jan Thyer Level 1
                                                            My problems with opening PDFs online both on XP and Snow Leopard seem to be miraculously resolved. Sorry, but I don't have a clue why!
                                                            • 27. Re: Problem with 9.3 Reader when opening files from internet
                                                              Laurence Burrows Level 1
                                                              I read all the posts on this topic and ran some experiments on my 'test' workstation.
                                                              Baseline: HP dc7900, 4GB, Win XP Pro (SP-3), all the updates/hotfixes, Acrobat Pro 8.2.1, FrameMaker 8.0p277, IE 8.0.6001.18702, TrendMicro AV.
                                                              FrameMaker does print to pdf/save to pdf with no problems. (Hi, Arnis)
                                                              1. Had Reader 9.2 installed, worked OK with IE 8.
                                                              2. Updated Reader to 9.3.0 then 9.3.1. got the sad message about can't open files. Killed the Reader 9.3.1, IE 8 beeped -- message "download halted to protect yr PC, etc, etc." Allowed download of pdf file to temp area but won't allow viewing.
                                                              3. Ran <Add or Remove Programs>, deleted Reader 9.3.1 et al.
                                                              4. Installed Reader 9.1 from my download archive.
                                                              5. Navigated to web page -- government tax site so prolly safe -- opened pdf file in browser. Can navigate back and forward OK.
                                                              Diagnosis: Acrobat Reader 9.3.x is Borked. For those who also follow the FrameMaker forums and the numerous posts re print to pdf/save as pdf from FrameMaker, I'd surmise that Acrobat Std/Pro/etc 9.3.x are also Borked.
                                                              • 28. Re: Problem with 9.3 Reader when opening files from internet
        wallywoowoo
        all a bit too tec for me, new computer running windows 7, adobe reader 9 doesnt work,  i just want to open the pdf downloads on
        my website, new version of reader seems crap, had to uninstall
        it and install pdf suite instead...where can i get the
        old adobe 8 version again ?
        • 29. Re: Problem with 9.3 Reader when opening files from internet
        godsdragon
        This solution worked for me, but I still want to know how to make adobe
        reader work well from within the web browser...
        Any ideas how to fix the browser or adobe? I am enrolled in school and can't afford wasting time downloading pdf files unless I am saving them to my computer...
        Thank you!
        • 30. Re: Problem with 9.3 Reader when opening files from internet
        godsdragon Level 1
        I was not able to find reader 9.1 grr... I had to download and reinstall 9.3.1 any links where I can find 9.1?
        Thank you
        • 31. Re: Problem with 9.3 Reader when opening files from internet
        Ubuntu17 Level 1
        Try this
        http://get.adobe.com/reader/otherversions/ select your OS and language and you can choose to download 9.3.1 or 8.2
        • 32. Re: Problem with 9.3 Reader when opening files from internet
        too green Level 1
        As I posted on Feb. 19 this is what works for me.  OS is Windows 7 64-bit, AdoveReader 9.3.1., IE8.
        Open Adobe Reader,
        go to edit menu,
        under Preferences
        or if you have Google tool bar installed:
        go to Tools
        uncheck Translate
        Or uninstall the Google tool bar.
        Pdf files open without a problem in Firefox.
        All of these solutions are easy.
        Too Green
        • 33. Re: Problem with 9.3 Reader when opening files from internet
        darent5556
        the firewal may stop the loading, it that isn't the problem try to uninstall and install the reader
        acne for acne
