• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Captivate CS4 Freezing on Preview Project
New Here ,
Feb 18, 2010 Feb 18, 2010
I'm creating my first project in Captivate 4.   Most times when I go to preview the project, it freezes and will not move on from the "Progress: Generating Slides" step.  The program stops responding, and I have to end the program using Taskmgr.   I have to do this several times (reopen Captivate, open the project, preview project) before it will finally generate the SWF and allow me to preview.
I don't know if it's necessary but I included a Word document on this post with my screen shots.
I checked with a workmate, and this is also happening to him as well.   He said it's very frustrating.  Any suggestions?
TOPICS
Getting started
Views
1.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Hello,
Nothing is attached.
How big is the project (number of slides, audio)?   Did you try to preview 5 slides and is it working then?  You'll have to provide some more information.
Lilybiri
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
I couldn't help but to notice that you said:
"I checked with a workmate, and this is also happening to him as well."
Does this mean you are both working on the same project? If so, does this mean the project that is freezing up is stored on a network drive?
If that's the case, that's likely the reason things are locking up. Captivate doesn't do well when you edit projects while they are stored on a network drive. Try closing Captivate and copying the project to your local C drive and see if things improve.
Cheers... Rick
Helpful and Handy Links
Captivate Wish Form/Bug Reporting Form
Adobe Certified Captivate Training
SorcerStone Blog
Captivate eBooks
Votes
Translate
Translate
Report
Report
New Here ,
Mar 15, 2010 Mar 15, 2010
I'm experiencing a similar problem - Captivate 4 freezes 90% of the time at the "Generating slides..." step when I'm publishing a project. It does this independent of the project I'm working on - size and content of the project don't seem to matter, although it seems that the first publish attempt after the Captivate project has been opened seems to have a better chance than any successive attempts. When it freezes, I have to end the task with Windows task manager, re-open the file, and then try publishing again until it finally publishes. The project files are located on my local machine, so it's not a network- or sharing-related issue. My co-workers don't seem to be experiencing the same issue, which leads me to believe that it's something machine-specific (corrupt install or interfering 3rd party software?), but I'd like to avoid having to reinstall Captivate unless there's no other solution. For the record, I installed Captivate as part of an Adobe eLearning suite installation. Here are my machine specs:
- Lenovo Thinkpad Intel Core2 Duo CPU
- P8600 @ 2.4 GHz, 1.94 GB of RAM
- WinXP Sp3
- Captivate 4.0.0, build 1596
Thanks in advance for any help you can provide!
Votes
Translate
Translate
Report
Report
Community Expert ,
Mar 16, 2010 Mar 16, 2010
Hello,
You have to install the patch released in May 2009: use menu Project, Updates. Apparently the automatic Adobe Updater is not installed on your machine. This patch resolved quite a lot of issues.
Lilybiri
Votes
Translate
Translate
Report
Report
Guest
Try and install the Captivate update to bring your build up to 4.0.1. 1658
Mike
Votes
Translate
Translate
Report
Report
New Here ,
Apr 01, 2010 Apr 01, 2010
LATEST
Thanks, Mike and Lily! I installed the update a week or two ago and haven't experienced the issue since then.
Votes
Translate
Translate
Report
Report
Resources
Help resources
