3 Replies Latest reply on Feb 19, 2010 4:21 AM by archemedia
    Visible property in ItemRenderer
    opiator
      Hi there,
      I have a very basic question. I'm trying to hide a canvas in the itemrender of a list
      <mx:List dataProvider="{currentCollection}" width="100%" height="100%">
        <mx:itemRenderer>
         <mx:Component>
          <mx:Canvas visible="false" includeInLayout="false">
          </mx:Canvas>
         </mx:Component>
        </mx:itemRenderer>
      It seems that it cannot hide the first element after component? the following code works:
        <mx:itemRenderer>
         <mx:Component>
          <mx:Canvas>
         <mx:Canvas visible="false"includeInLayout="false">
            </mx:Canvas>
          </mx:Canvas>
         </mx:Component>
        </mx:itemRenderer>
      But that is pretty pointless-the top canvas anyway takes up the space
      Any idea how to hide items in a list? Do i have to make my own itemrenderer?
      any advice would be appreciated
        • 1. Re: Visible property in ItemRenderer
          archemedia Level 4
          If you want to hide items in a list, simply filter the out of the dataProvider! Use the filterfunction of the ArrayCollection class for that. An example:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" creationComplete="init()">
              <mx:Script>
                  <![CDATA[
                      import mx.collections.ArrayCollection;
                      [Bindable]
                      private var dp:ArrayCollection;
                      private function init():void
                          var a:Array = [{label: "Item 1", available: 1},
                                          {label: "Item 2", available: 0},
                                          {label: "Item 3", available: 0},
                                          {label: "Item 4", available: 1},
                                          {label: "Item 5", available: 1}];
                          dp = new ArrayCollection(a);
                      public function filterAvailable(item:Object):Boolean
                          return (item.available == 1);
              </mx:Script>
              <mx:List dataProvider="{dp}" width="400" height="400" labelField="label"/>
              <mx:Button label="Show available" click="dp.filterFunction = filterAvailable;dp.refresh()"/>
              <mx:Button label="Show all" click="dp.filterFunction = null;dp.refresh()"/>
          </mx:Application>
          Hope this helps
          Dany
          • 2. Re: Visible property in ItemRenderer
            opiator Level 1
            Hi
            Thanx for the reply. I have a list of RSS items,after 20 items,I want display a button with "Show older items" and hide all old entries in the list
            The thing is my currentCollection is being used throughout the whole application,so filtering the objects out would require some extra ArrayCollections to store the filtered out items. But I guess at this point it's the best solution.
            Thanx for the help
            • 3. Re: Visible property in ItemRenderer
              archemedia Level 4
              There is an alternative:
              Take two arrayCollections. The first one holds your application data, so you shouldn't filter this right?
              The second one is bound to the dataProvider of your list.
              Now, use the filter function of the source array of your first collection to fill your second one. The array.filter function creates a new array!
                  <mx:Script>
                      <![CDATA[
                          [Bindable]
                          private var mainColl:ArrayCollection;
                          [Bindable]
                          private var dp:ArrayCollection = new ArrayCollection();
                              mainColl = new ArrayCollection(a);
                              showAll();
                          public function filterAvailable():void
                              dp.source = mainColl.source.filter(function callback(item:*, index:int, array:Array):Boolean
                                          return item.available == 1;
                          public function showAll():void
                                          return true;
                  </mx:Script>
                  <mx:HBox>
                      <mx:List dataProvider="{mainColl}" width="400" height="400" labelField="label"/>
                  </mx:HBox>
                  <mx:Button label="Show available" click="filterAvailable()"/>
                  <mx:Button label="Show all" click="showAll()"/>
              </mx:Application>
              Dany
