2 Replies Latest reply on Feb 19, 2010 4:38 AM by JockMahon
    Close button in panel
    JockMahon
      How do i put
      components in the header of a panel so like a minamise button for example
      thanks
        • 1. Re: Close button in panel
          David_F57 Level 5
          there are several ways you can do this, my personal favorite is through the skin so that way if I already have several panels I want to apply the effect to I just set the skin.
          I have attached a very simple project that opens and closes a panel with a button,
          All I did was reduce the minheight of the component to 30 created a button on the title bar , added a variable to hold the original height and a click event for the button
          protected function expandBtn_clickHandler(event:MouseEvent):void
          if (hostComponent.height == fullHeight) hostComponent.height = 32 else hostComponent.height=fullHeight;
          Its a simple example you would probably put more into a 'nice' toggle button caption etc but it gives you a little insight into one persons ideas
          David
          • 2. Re: Close button in panel
            JockMahon Level 1
            That's great. Thank you for your time!
