2 Replies Latest reply on Feb 21, 2010 5:24 PM by aliandri
    how to make multiple choice with random question ?
    aliandri
      Hi everybody....
      i'm introduce that my name Ali and i have problem on lingo...
      i try to make question with multiple choice but i want to make random question any time who access that so any time can be different number question...
      i try make code with instruction random() but sometimes that question are same...
      i try this code :
      global rad
      on mouseUp me
        rad=random(11)
        case rad of
          1: _movie.go("1")
          2: _movie.go("2")
          3: _movie.go("3")
          4: _movie.go("4")
          5: _movie.go("5")
          6: _movie.go("6")
          7: _movie.go("7")
          8: _movie.go("8")
          9: _movie.go("9")
          10: _movie.go("10")
          11: _movie.go("11")
        end case
      end
      any body help me?
      if not exception can send by email to aandrie77@yahoo.com
      thank you....
        • 1. Re: how to make multiple choice with random question ?
          James Newton, ACP Level 3
          If I understand correctly, you have 11 questions and you want to ask them once each in a random order.  To do this, you could create a randomized list, and use-and-remove one item at a time.  Here's a simple demo:
          1) Create a new movie
          2) Create a graphic member of some type and drag it onto the Stage
          3) Create a movie script
          4) Paste the scriptText below into the movie script
          5) Run your movie
          6) Open the Score window
          7) Click on the Stage several times and watch how the playback head jumps about in the Score window
          -- RANDOM FRAME--
          -- Movie script
          global gFrameList
          on exitFrame
            go the frame
          end
          on startMovie()
            -- Create an ordered list
            gFrameList = []
            vCount = 11
            repeat with ii = 1 to vCount
              gFrameList[ii] = ii -- use QUOTE&ii&QUOTE if you want marker names
            end repeat
            -- Shuffle the list
            ii = vCount
            repeat while ii -- repeat until ii becomes zero
              -- Choose a random item...
              vRandom = random(ii)
              vItem = gFrameList[vRandom]
              -- ... and move it to the end
              gFrameList.deleteAt(vRandom)
              gFrameList.append(vItem)
              ii = ii - 1
            end repeat
            put gFrameList -- look in the Message window
          end startMovie
          on mouseUp()
            if gFrameList.count then
              -- Use and lose the first item in the list
              vFrame = gFrameList[1]
              gFrameList.deleteAt(1)
              go vFrame
            else
              alert "gFrameList is now empty"
              halt
            end if
          end mouseUp
          • 2. Re: how to make multiple choice with random question ?
            aliandri Level 1
            Thank you sir,
            it's work but i change list about on mouseUp with another name procedure for call that procedure on another behavior script... so this list with my modification (on bold font) :
            -- RANDOM FRAME--
            -- Movie script
            global gFrameList
            on exitFrame
              go the frame
            end
            on startMovie()
              gFrameList = []
              vCount = 11
              end repeat
              -- Shuffle the list
              ii = vCount
                ii = ii - 1
              end repeat
            end startMovie
            on actionbutton() -- mouseUp ()
                go vFrame
              else
                halt
              end if
            end actionbutton --mouseUp
