6 Replies Latest reply on Feb 22, 2010 12:19 AM by jake_flex
    MXML is XML like?
    jake_flex
      This is more of a discussion about Flex/MXML in general, not a direct question.
      I have read some tutorials/books stating that MXML is XML like markup language. I have worked with MXML for a while now and so far I haven't seen anything in MXML that wasn't also valid XML. The only difference is the the filename ending.
      Is there more to Flex/MXML that I haven't seen yet?
      It's a free discussion, the stage is yours.
        • 1. Re: MXML is XML like?
          archemedia Level 4
          No! Flex is pure XML:
          Dany
          • 2. Re: MXML is XML like?
            jake_flex Level 2
            Dany
            Thanks for the reply Dany.
            That's what I thought also. I have the "Programming Flex 3" book (1st ed.) by Chafic Kazoum and Joey Lott and on page 35 it states
            MXML is a dedclarative markup language used to create the user interface
            and to view portions of Flex applications. As the name implies, MXML is an XML-based language.
            That's pretty much the reason I started this discussion.
            P.S. I have to book in physical format, so copying the above citation was done 'by hand', so it might contain some typos, but the relative information is correct.
            • 3. Re: MXML is XML like?
              msakrejda Level 4
              It's XML-based. That means that there are things that are valid XML that are *not* valid MXML (e.g., your root tag always needs to correspond to an existing component). I think that's what is meant by the distinction.
              • 4. Re: MXML is XML like?
                jake_flex Level 2
                Thanks for the reply msakrejda,
                Isn't that something that is relevant at the compile phase e.g. the mxml compiler was written in such a manner that it cheks that the root tag is an already existing component.
                XML it self has quite a few limitations. The limitations come from the program reading XML or the schema/DTD used to validate it.
                Why did they call it MXML? I guess it's marketing.
                • 5. Re: MXML is XML like?
                  Gregory Lafrance Level 6
                  MacromediaXML for the company (merged with Adobe) that created MXML.
                  If this post helps, please mark it as such.
                  Greg Lafrance - Flex 2 and 3 ACE certified
                  www.ChikaraDev.com
                  Flex / AIR Development, Training, and Support Services
                  • 6. Re: MXML is XML like?
                    jake_flex Level 2
                    www.ChikaraDev.com
                    Thanks Greg, that explaines the name.
