10 Replies Latest reply on Oct 2, 2007 3:56 PM by Newsgroup_User
    png fix for css images
    Level 7
      Hi - I have this page i am working on
      http://www.crackerjackpromotions.co.nz/2007/index3.php and the middle
      navigation icons are png8. The only way i could get the text left icons
      right and all clickable was to put the images as background css images. They
      look fine in most browsers but the older ie ones do not display them
      properly so I thought i could use the png fix but it seems to be only for
      images that are in the html, not in the css....... Anyone know a way i can
      fix this?
      Karen
        • 1. Re: png fix for css images
          Level 7
          Try this html instead of using icons as background images.
          <td width="27%" class="corporate"><a href="#">CORPORATE EVENTS <img
          src="myicon.png" width="20" height="20" alt="myicon"></a></td>
          --Nancy O.
          Alt-Web Design & Publishing
          www.alt-web.com
          "Karenj" <webforumsuser@macromedia.com> wrote in message
          news:fdmq6u$27p$1@forums.macromedia.com...
          They
          > fix this?
          > Thanks,
          > Karen
          • 2. Re: png fix for css images
            Level 7
            Hi Nancy - I have tried that but then i cannot get the icons to align right
            and then text left plus have the whole lot clickable. When i make the a link
            as display block it makes the image move down, hence the only way i have
            managed to get what I need for the function and look is to have the icons as
            bg css images. I guess i can just make the images gifs, but i was trying to
            learn the png fix only to find I can't use it in this situation.
            Thanks for looking
            Karen
            "Nancy O" <nancyoshea1@NOSPAMverizon.net> wrote in message
            news:fdohp1$s2r$1@forums.macromedia.com...
            > --Nancy O.
            > www.alt-web.com
            > They
            >> can
            >> fix this?
            >> Thanks,
            >> Karen
            • 3. Re: png fix for css images
              Level 7
              > but i was trying to learn the png fix only to find I can't use it in this
              > situation.
              I can't think of a single reason why you would not be able to use it. Can
              you explain?
              Murray --- ICQ 71997575
              Adobe Community Expert
              (If you *MUST* email me, don't LAUGH when you do so!)
              http://www.dreamweavermx-templates.com - Template Triage!
              http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
              http://www.dwfaq.com - DW FAQs, Tutorials & Resources
              http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
              news:fdp7a4$j4t$1@forums.macromedia.com...
              > right and then text left plus have the whole lot clickable. When i make
              > the a link as display block it makes the image move down, hence the only
              > way i have managed to get what I need for the function and look is to have
              > the icons as bg css images. I guess i can just make the images gifs, but i
              > situation.
              > Thanks for looking
              > Karen
              >> --Nancy O.
              >> www.alt-web.com
              >> They
              >>> for
              >>> can
              >>> fix this?
              >>> Thanks,
              >>> Karen
              • 4. Re: png fix for css images
                Level 7
                Hi Murray - well from your post I assume that what i want to do is possible
                so all that is stopping me is a lack of knowledge :-)
                I have tried to implement the fix using this info
                http://www.twinhelix.com/css/iepngfix/
                http://bjorkoy.com/past/2007/4/8/the_easiest_way_to_png/ but so far have not
                got it working....
                I will keep trying!
                Karen
                "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
                news:fdp7oc$jg3$1@forums.macromedia.com...
                >> situation.
                > you explain?
                >> have the icons as bg css images. I guess i can just make the images gifs,
                >> situation.
                >> Thanks for looking
                >> Karen
                >>> --Nancy O.
                >>> www.alt-web.com
                >>> They
                >>>> for
                >>>> can
                >>>> fix this?
                >>>> Thanks,
                >>>> Karen
                • 5. Re: png fix for css images
                  Level 7
                  Show us the page where you have tried, please.
                  And what is it you are expecting this png fix to do for you?
                  news:fdpcc9$nrq$1@forums.macromedia.com...
                  > possible so all that is stopping me is a lack of knowledge :-)
                  > not got it working....
                  > I will keep trying!
                  > Thanks,
                  > Karen
                  >>> this situation.
                  >> Can you explain?
                  >>> gifs, but i was trying to learn the png fix only to find I can't use it
                  >>> in this situation.
                  >>> Thanks for looking
                  >>> Karen
                  >>>> --Nancy O.
                  >>>> www.alt-web.com
                  >>>>> icons
                  >>>>> images.
                  >>>> They
                  >>>>> for
                  >>>>> can
                  >>>>> fix this?
                  >>>>> Thanks,
                  >>>>> Karen
                  • 6. Re: png fix for css images
                    Level 7
                    PNG transparency fix doesn't work on BG images.
                    --Nancy O.
                    www.alt-web.com
                    possible
                    not
                    > got it working....
                    > I will keep trying!
                    > Thanks,
                    > Karen
                    this
                    > >> situation.
                    Can
                    > > you explain?
                    only
                    gifs,
                    this
                    > >> situation.
                    > >> Thanks for looking
                    > >> Karen
                    > >>> --Nancy O.
                    > >>> www.alt-web.com
                    icons
                    images.
                    > >>> They
                    > >>>> for
                    i
                    > >>>> can
                    > >>>> fix this?
                    > >>>> Thanks,
                    > >>>> Karen
                    • 7. Re: png fix for css images
                      Level 7
                      Hi Murray, the page is
                      On the middle navigation the icons to the right of the text links are png
                      images with bg transparency. They look as they should in ie7 ff opera but in
                      older versions of ie they don't look right. Try looking in ie6 - I have made
                      the corporate events icon a gif (not the rollover though) and that looks
                      normal but the others don't. I could make all of them transparent gifs, but
                      my plan was to learn more about png and how to get the transparency to work
                      in older ie's.
                      The webfx fix i looked at first was for forground images
                      http://webfx.eae.net/dhtml/pngbehavior/pngbehavior.html which wasn't for me.
                      Now i've been trying with info from these sites
                      So i have my iepngfix.htc file uploaded with the path amended to my
                      blank.gif. Then in my css I have
                      img { behavior: url(iepngfix.htc); }
                      or i've currently just tried:
                      img, #wrapper2midnav td { behavior: url(iepngfix.htc) }
                      Plus other variations..
                      But so far the png images still look odd in ie6. I'm not even 100% sure it's
                      a transparency thing since i read that ie6 puts a grey box instead of the
                      transparent bit, but thats not what I'm getting, my png images just look
                      jagged edged and bitty.
                      Oko hope that explanation covers it!, thanks for looking,
                      Cheers,
                      Karen
                      news:fdqqds$cc0$1@forums.macromedia.com...
                      >> I will keep trying!
                      >> Thanks,
                      >> Karen
                      >>>> this situation.
                      >>> Can you explain?
                      >>>> only way i have managed to get what I need for the function and look is
                      >>>> to have the icons as bg css images. I guess i can just make the images
                      >>>> in this situation.
                      >>>> Thanks for looking
                      >>>> Karen
                      >>>>> --Nancy O.
                      >>>>> www.alt-web.com
                      >>>>>> icons
                      >>>>>> images.
                      >>>>> They
                      >>>>>> for
                      >>>>>> i can
                      >>>>>> fix this?
                      >>>>>> Thanks,
                      >>>>>> Karen
                      • 8. Re: png fix for css images
                        Level 7
                        I am looking in IE6, and they look fine.
                        news:fds6q7$sa$1@forums.macromedia.com...
                        • 9. Re: png fix for css images
                          Level 7
                          Hi Murray - probably because I changed them all to gifs now! I need to
                          progress on this job so will try the transparent png thing later, Thanks,
                          Karen
                          news:fdubu3$g70$1@forums.macromedia.com...
                          • 10. Re: png fix for css images
                            Level 7
                            Good luck!
                            news:fduf9c$jff$1@forums.macromedia.com...
                            > Karen
