4 Replies Latest reply on Feb 19, 2010 12:43 PM by 2bgeek
    Extracting values from xml tags in wsdl
    2bgeek
      I have a process which makes an LDAP call. I have an output variable of type xml and have an xsd referenced to it. The XSD has been imported in the wsdl of the process and I am using the manipulated wsdl file to invoke the process from a pdf form. The tags of the xml output variable do appear in the response wsdl, but they are under the document tag under the variable name and are in the CDATA section. Is there any way that I can have a fiel in the form and directly bind it to the elements in the return xml. I tried binding the elements, but the field does not show any value even when the reponse has the value in it.
      Please help.
      Regards,
      Nakul
