0 Replies Latest reply on Feb 19, 2010 1:09 PM by Carol L. Frampton
    [svn:fx-4.x] 14289: Fix DataGrid mirroring issues when layoutDirection="rtl " and direction="rtl":
    Carol L. Frampton Level 2
      Revision: 14289
      Revision: 14289
      Author:   cframpto@adobe.com
      Date:     2010-02-19 13:08:54 -0800 (Fri, 19 Feb 2010)
      Log Message:
      Fix DataGrid mirroring issues when layoutDirection="rtl" and direction="rtl":
      - headers get messed up when resizing, moving or sorting a column because the transform matrix in UIFTETextField wasn?\226?\128?\153t always updated when width was changed
      - when moving a column, the headerSelection sprite was moving in the wrong direction
      - when dragging a row, the drag image was backwards and the x offset between the image and the mouse pointer was wrong
      QE notes:
      Doc notes: None
      Bugs: SDK-25424, SDK-25426, SDK-25440, SDK-25442, SDK-25452, SDK-25460, SDK-25462, SDK-25464
      Reviewed By: Hans
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25424
          http://bugs.adobe.com/jira/browse/SDK-25426
          http://bugs.adobe.com/jira/browse/SDK-25440
          http://bugs.adobe.com/jira/browse/SDK-25442
          http://bugs.adobe.com/jira/browse/SDK-25452
          http://bugs.adobe.com/jira/browse/SDK-25460
          http://bugs.adobe.com/jira/browse/SDK-25462
          http://bugs.adobe.com/jira/browse/SDK-25464
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/DataGrid.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataG ridDragProxy.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataG ridHeader.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/UITextField.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/managers/DragManagerImpl.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/mx/core/UIFTETextField.as
