0 Replies Latest reply on Feb 19, 2010 4:12 PM by dridgway
    Newbie CSS Help (IE-related position problem)
    dridgway
      I've spent a good amount of time scouring the web for an answer that I can apply but haven't had any luck. Essentially, the problem is that the left column (sidebar1) doesn't 'top-align' with the 'maincontent'. The link to the test site is: http://dougridgway.com/temp_adobe/ — the CSS is below.
      The site looks good in Safari:
      Thanks in advance for any feedback/help!
      @charset "UTF-8";
      body  {
      font: 100% Verdana, Arial, Helvetica, sans-serif;
      background: #666666;
      margin: 0 0 0 0; /* it's good practice to zero the margin and padding of the body element to account for differing browser defaults */
      padding: 0;
      text-align: center; /* this centers the container in IE 5* browsers. The text is then set to the left aligned default in the #container selector */
      color: #000000;
      .twoColFixLtHdr #container {
      width: 965px; /* this overrides the text-align: center on the body element. */
      vertical-align: top;
      background: transparent;
      height: auto;
      margin: auto;
      .twoColFixLtHdr #header {
      padding: 0 0 0 0;  /* this padding matches the left alignment of the elements in the divs that appear beneath it. If an image is used in the #header instead of text, you may want to remove the padding. */
      height: 85px;
      .twoColFixLtHdr #header h1 {
      margin: 0 0 0 0; /* using padding instead of margin will allow you to keep the element away from the edges of the div */
      height: 110px;
      background-color: transparent;
      .twoColFixLtHdr #sidebar1 {
      height: 800px;
      font-family: Georgia, "Times New Roman", Times, serif;
      float: left;
      width: 169px;
      position: static;
      margin: 0 0 0 0;
      .twoColFixLtHdr #mainContent {
      float: left;
      height: 800px;
      width: 796px;
      background-color: #fff;
      text-align: left;
      position: static;
      margin: 0 0 0 0;
      .twoColFixLtHdr #footer {
      background:transparent;
      width: 965px;
      text-align: center;
      .twoColFixLtHdr #footer p {
      margin: 0; /* zeroing the margins of the first element in the footer will avoid the possibility of margin collapse - a space between divs */
      padding: 10px 0; /* padding on this element will create space, just as the the margin would have, without the margin collapse issue */
      .fltrt { /* this class can be used to float an element right in your page. The floated element must precede the element it should be next to on the page. */
      float: right;
      margin-left: 8px;
      .fltlft { /* this class can be used to float an element left in your page */
      float: left;
      margin-right: 8px;
      .clearfloat { /* this class should be placed on a div or break element and should be the final element before the close of a container that should fully contain a float */
      clear:both;
      height:0;
      font-size: 1px;
      line-height: 0px;
      width: 965px;
