5 Replies Latest reply on Feb 23, 2010 4:11 AM by Francisc
    LineChart with two X-axis
    Francisc Level 3
      Hello!
      How can I implement the LineChart component to have two X-axis like in the screenshot attached?
      Note: The Y axis is the same for both line charts, not inverted or anything.
      Thank you!
        • 1. Re: LineChart with two X-axis
          Francisc Level 3
          "bump" (Greg, 2010)
          • 2. Re: LineChart with two X-axis
            vinit doshi
            you can use "type" in that
            linechat
            • 3. Re: LineChart with two X-axis
              vinit doshi Level 1
              here is a code where it shows 2 y axis just alter this to x axis and do the needful
              <?xml version="1.0"?>
              <!-- charts/MultipleAxes.mxml -->
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
                <mx:Script><![CDATA[
                   import mx.collections.ArrayCollection;
                   [Bindable]
                    public var SMITH:ArrayCollection = new ArrayCollection([
                      {date:"22-Aug-05", close:41.87},
                      {date:"23-Aug-05", close:45.74},
                      {date:"24-Aug-05", close:42.77},
                      {date:"25-Aug-05", close:48.06},
                   [Bindable]
                    public var DECKER:ArrayCollection = new ArrayCollection([
                      {date:"22-Aug-05", close:157.59},
                      {date:"23-Aug-05", close:160.3},
                      {date:"24-Aug-05", close:150.71},
                      {date:"25-Aug-05", close:156.88},
                ]]></mx:Script>
                <mx:Panel title="Column Chart With Multiple Axes">
                   <mx:ColumnChart id="myChart" showDataTips="true">
                      <mx:horizontalAxis>
                         <mx:CategoryAxis id="h1" categoryField="date"/>
                      </mx:horizontalAxis>
                      <mx:horizontalAxisRenderers>
                          <mx:AxisRenderer placement="bottom" axis="{h1}"/>
                      </mx:horizontalAxisRenderers>
                      <mx:verticalAxisRenderers>
                          <mx:AxisRenderer placement="left" axis="{v1}"/>
                          <mx:AxisRenderer placement="left" axis="{v2}"/>
                      </mx:verticalAxisRenderers>
                      <mx:series>
                         <mx:ColumnSeries id="cs1"
                              horizontalAxis="{h1}"
                              dataProvider="{SMITH}"
                              yField="close"
                              displayName="SMITH"
                              <mx:verticalAxis>
                                 <mx:LinearAxis id="v1" minimum="40" maximum="50"/>
                              </mx:verticalAxis>
                         </mx:ColumnSeries>
                         <mx:LineSeries id="cs2"
                              dataProvider="{DECKER}"
                              yField="close"
                              displayName="DECKER"
                              <mx:verticalAxis>
                                  <mx:LinearAxis id="v2" minimum="150" maximum="170"/>
                              </mx:verticalAxis>
                         </mx:LineSeries>
                      </mx:series>
                   </mx:ColumnChart>
                   <mx:Legend dataProvider="{myChart}"/>
                </mx:Panel>
              </mx:Application>
              • 4. Re: LineChart with two X-axis
                Francisc Level 3
                Thanks for the answer!
                I'll give it a test tomorrow latest and come-up with the "verdict".
                • 5. Re: LineChart with two X-axis
                  Francisc Level 3
                  Thanks!
