3 Replies Latest reply on Feb 20, 2010 6:56 AM by David_F57
    Will the bound dimension values update when the application changes size?
    nikos101 Level 2
      If I do this will the values update when the application changes size?
          <s:Rotate3D
                              angleYFrom="0" angleYTo="-90"
                              angleXFrom="0" angleXTo="90"
                              repeatBehavior="{RepeatBehavior.REVERSE}"
                              transformY="{-12345678/this.height}"
                              transformX="{-12345678/this.width}"
                              repeatCount="2" duration="1200"
                              effectEnd="effectEndHandler(event)">
        • 1. Re: Will the bound dimension values update when the application changes size?
          David_F57 Level 5
          The example code is not 'bound' in the traditional sense as the rotate will only happen when you call it, so the height/width used when you call the rotate function will always be whatever the current value is.
          David.
          • 2. Re: Will the bound dimension values update when the application changes size?
            nikos101 Level 2
            Cool thanks
            I've been trying to get a component to dissappear off the top right hand
            side of the screen no matter what the application dimensions are. But its
            harder than I think, hear is what I've tried
                <s:Rotate3D
                                    angleYFrom="0" angleYTo="{-0.08*this.height}"
                                    angleXFrom="0" angleXTo="{0.08*this.width}"
                                    transformY="{-20000}"
                                    transformX="{-20000}"
                            <s:effectRepeat>
                                <![CDATA[
                                customEditor.editor.textFlow = new TextFlow();
                            </s:effectRepeat>
                        </s:Rotate3D>
            Any ideas what I need to change
            best wishes
            Nikos
            • 3. Re: Will the bound dimension values update when the application changes size?
              David_F57 Level 5
              I would approach things a little differently, the following app will show/hide a panel, now you could obviously do this with transitions etc but the principle stays the same use negative dimensions on the side you want to transition on (top/left/bottom/right). You could also do this for say a panel inside another panel in that case you would disable scroll policy and myou may need to set the clip rect.
                 xmlns:mx="library://ns.adobe.com/flex/mx" top="0" left="0" bottom="0" right="0">
              <fx:Script>
              <![CDATA[
              protected function button1_clickHandler(event:MouseEvent):void
              if (pnl.right==0) pnl.right=(-pnl.width) else pnl.right=0;
              </fx:Script>
              <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
              </fx:Declarations>
              <s:Panel id="pnl" width="250" height="200" right="0" top="0">
              </s:Panel>
              <s:Button label="Button" horizontalCenter="0" verticalCenter="0" click="button1_clickHandler(event)"/>
              </s:Application>
