8 Replies Latest reply on Mar 26, 2007 4:27 AM by Newsgroup_User
    Object expected error in IE
    romeo_the_3rd
      Hi
      2 issues:
      First is:
      Line 80
      URL: www.5minuteretreats.com
      I don't know if its the MMpreload images or the PLHFO menu it is referring to.
      Second is:
      Also getting "line 271 column 16: end tag for element "A" which is not open."
      p="</a>";
      I am unsure of the <a> tag. It appears to be part of the Random Image script (kaosweaver - DW extension). Not sure what would happen if I delete it.
      Any assitance would be great.
      R3
        • 1. Re: Object expected error in IE
          Level 7
          The error is referring to line 505. You have hacked the HALO menu system
          incompletely and left some js at the bottom of the page that is causing the
          errors to appear.
          Read this - it will describe the menu's workings enough so that you can
          figure out what needs to be done....
          http://www.macromedia.com/devnet/mx/dreamweaver/articles/dissecting_halo.html
          Change this -
          p="</a>";
          to this -
          p="</" + "a>";
          Paul Davis should know better! 8)
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "romeo the 3rd" <webforumsuser@macromedia.com> wrote in message
          news:eu516k$bep$1@forums.macromedia.com...
          > Hi
          > 2 issues:
          > First is:
          > Line 80
          > to.
          > Second is:
          > open."
          > p="</a>";
          > script
          > R3
          • 2. Re: Object expected error in IE
            Level 7
            This onmousemove on the <body> tag is causing the error:
            onmousemove="closesubnav(event);"
            Ken Ford
            Fordwebs, LLC
            http://www.fordwebs.com
            "romeo the 3rd" <webforumsuser@macromedia.com> wrote in message news:eu516k$bep$1@forums.macromedia.com...
            > Hi
            > 2 issues:
            > First is:
            > Line 80
            > Second is:
            > p="</a>";
            > R3
            • 3. Re: Object expected error in IE
              Level 7
              That too. There is detritus all over the page that should be removed.
              "Ken Ford - *ACE*" <newsgroups@fordwebs.com> wrote in message
              news:eu5p57$99k$1@forums.macromedia.com...
              > Ken Ford
              > Fordwebs, LLC
              >> Hi
              >> 2 issues:
              >> First is:
              >> Line 80
              >> referring to. Second is:
              >> open."
              >> p="</a>"; I am unsure of the <a> tag. It appears to be part of the Random
              >> delete it.
              >> R3
              • 4. Re: Object expected error in IE
                Level 7
                College educated people.
                I had to look up the word :-)
                http://www.m-w.com/dictionary/detritus
                Ken Ford
                Fordwebs, LLC
                "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message news:eu5qse$b7d$1@forums.macromedia.com...
                >> Ken Ford
                >> Fordwebs, LLC
                >>> Hi
                >>> 2 issues:
                >>> First is:
                >>> Line 80
                >>> open."
                >>> delete it.
                >>> R3
                • 5. Re: Object expected error in IE
                  Level 7
                  8) - what makes you think I *didn't* have to look it up?
                  I thought about using "flotsam", but decided not to....
                  news:eu5r87$bhu$1@forums.macromedia.com...
                  > Ken Ford
                  > Fordwebs, LLC
                  >>> Ken Ford
                  >>> Fordwebs, LLC
                  >>>> Hi
                  >>>> 2 issues:
                  >>>> First is:
                  >>>> Line 80
                  >>>> open."
                  >>>> R3
                  • 6. Re: Object expected error in IE
                    romeo_the_3rd Level 1
                    Thanks for the replies. I appreciate it.
                    'This onmousemove on the <body> tag is causing the error:
                    onmousemove="closesubnav(event);"'
                    How do I rectify this?
                    As for detritus (I would have used 'dross'), I know that the template must be full of it.
                    Do you have any suggestions as a starting point that could help a novice IT hack clean up the mess?
                    R3
                    • 7. Re: Object expected error in IE
                      Level 7
                      It doesn't seem to do anything so I would just remove that from the <body> tag.
                      Ken Ford
                      Fordwebs, LLC
                      "romeo the 3rd" <webforumsuser@macromedia.com> wrote in message news:eu84b5$5te$1@forums.macromedia.com...
                      > full of it.
                      > R3
                      • 8. Re: Object expected error in IE
                        Level 7
                        It does do something - fires an error every time the mouse moves, because
                        only half of the HALO menu has been removed.
                        The steps would be -
                        1. Remove the onmousemove event/call from the body tag.
                        2. Remove the (now) extraneous js from the bottom of the page, defining the
                        defunct menu.
                        The link I posted will guide you.
                        news:eu88mq$asf$1@forums.macromedia.com...
                        > tag.
                        > Ken Ford
                        > Fordwebs, LLC
                        >> must be full of it.
                        >> R3
