23 Replies Latest reply on Jun 25, 2015 10:38 AM by frederickyocum
    Selectable text from an alert dialog?
    John Hawkinson Level 5
      Javascript InDesign CS3 on a Mac, if that matters.
      I took a quick look through the ScriptUI docs and couldn't find a widget for this, but maybe I missed it.
      I'd like to display some alert text from a script and have the text in the alert dialog be cut-and-pasteable by the user. Is there an easy way to do this?
      I'd really rather not have the text be editable-in-the-dialog by the user (looks ugly), and I'm absolutely happy with the quick-and-dirty interface of alert() -- that is, just passing a long string with internal newlines, and not having to spend much time mucking around with ScriptUI and dialog properties and layouts and layout managers, etc., etc.
      Anyhow, is there a good way to do this? (I suppose I could pop up a dialog using AppleScript, but that really seems like the wrong answer...)
      Thanks.
        • 1. Re: Selectable text from an alert dialog?
          Harbs. Level 6
          An easy hack is to use prompt() instead of alert()
          Harbs
          • 2. Re: Selectable text from an alert dialog?
            That's already in InDesign! Press Ctrl/Cmd+C when an alert is on screen, and you can paste its text where you want.
            • 3. Re: Selectable text from an alert dialog?
              Harbs. Level 6
              Jong,
              Is that a Windows thing? I just tried that and I couldn't get it to work...
              Harbs
              • 4. Re: Selectable text from an alert dialog?
                Peter Kahrel Adobe Community Professional & MVP
                It works on Windows -- didn't know that either. But you get everything: dialog title followed by a dashed line followed by the alert text, followed by another dashed line, folloed by "OK". So your prompt-trick is probably neater.
                Peter
                • 5. Re: Selectable text from an alert dialog?
                  So, prompt() uses editable text...that's pretty ugly. But more importantly, it doesn't work for multiline items of text.
                  (There's a certain irony here -- if it's short enough to work with prompt(), it was probably short enough that you didn't need to cut-and-paste it.)
                  Ctrl-C and Command-C do not appear to work in alert() dialog boxes under OSX.
                  Other ideas?
                  • 6. Re: Selectable text from an alert dialog?
                    Harbs. Level 6
                    It does work with multi-line text -- you just can't see it all...
                    Try this:
                    prompt('Hi','this is some really long text.\r we have quite a few lines here.\r let us see how this works if we want to copy and paste!');
                    Like I said it's a bit of a hack...
                    A Script UI EditText is probably more what you want.
                    Set the multiline and readonly properties to true, and that should be exactly what you are after...
                    (It's a bit more work though...)
                    Harbs
                    • 7. Re: Selectable text from an alert dialog?
                      Shonkyin Level 3
                      You can also use confirm(). See attached screen shot.
                      copy your text on click Yes and continued your script, if click on No then continued without copy text.
                      Shonky
                      • 8. Re: Selectable text from an alert dialog?
                        Harbs, the readonly property of EditText is what I was looking for, I hadn't found that. That makes EditText acceptable, thanks! (I'm still struggling to get this right, but I'll post my reslult in a bit).
                        Shonky, confirm() doesn't seem to work under OSX for this. Perhaps it's like Ctrl-C in alert()  -- Windows only?
                        • 9. Re: Selectable text from an alert dialog?
                          Shonkyin Level 3
                          confirm() working on OSX. I am also using OSX.
                          Use below code:
                          var hello = 'Hello World'
                          result  = confirm (hello + '\r\r\r Copy result...')
                          if (result == 1)
                             var tf = app.activeDocument.textFrames.add (
                                geometricBounds: [0,0,100,100],
                                contents: hello}
                          app.select(tf.texts)
                          app.copy();
                          tf.remove()
                          Shonky
                          • 10. Re: Selectable text from an alert dialog?
                            OK, here is what I ended up with:
                            var long1="Eliquipit dolorem nummolo reetumsandit niam quis,\n"+
                            "nullums andiat lore. feugait am quis nullaor ad tat ilisim,\n"+
                            "acillan dionsed dunt augueraessim in ulputpa tumsandreet,\n"+
                            "illamet nullandre min eu faccum venim velese venibh,\n"+
                            "eraessisit ad ming ex etum nosto dionsectet, conseniam,\n"+
                            "irit praesto. consed estrud ex ea faci tatet in veni,\n"+
                            "ad tatumsa ndipsummodo ea facing esto dolenis ea acipsummy.";
                            function ealert(message, title, errorIcon) {
                              var d = new Window('dialog', title);
                              var msg = message.split("\n");
                            var icon = ScriptUI.newImage(
                            "/Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/"+
                            "Contents/Frameworks/adobe_registration.framework/Versions/A/Resources/warning_icon.png"
                              var f = d.graphics.font;
                              d.top     = d.add("group"); d.top.orientation="row";
                              d.left     = d.top.add("group", undefined);
                              d.ico     = d.left.add('image', undefined, icon);
                              d.right     = d.top.add("group", undefined); d.right.orientation="column";
                              d.bold = d.right.add('statictext', undefined, msg[0]);
                              d.bold.graphics.font = ScriptUI.newFont(f.name,ScriptUI.FontStyle.BOLD,f.size);
                              d.rom     = d.right.add('edittext', undefined, msg.slice(1).join("\n"),
                                {readonly:true, borderless: true, multiline: true, scrollable: false,
                              d.rom.graphics.font = ScriptUI.newFont(f.name,f.style,f.size-2);
                              d.rom.alignment="fill";
                              d.ok     = d.add("button", undefined, "OK", { name: "ok"});
                              d.ok.alignment = "right";
                              d.show();
                            ealert(long1, "myTitle");
                            It's not quite what I wanted, but it's close. Compare the alert() output:
                            to my script's ealert() output:
                            So that leaves me wondering:
                            1. How can I get InDesign's normal alert icon? I have the sense that if I knew what to refer to it as, I could use it. Does it have some kind of $ID/somethingorother name?
                            2. How can I get rid of the scrollbar and set the text background to grey? I get an error trying to set d.rom.graphics.backgroundColor.
                            app.copy();
                            Oh! I misunderstood you completely! Very clever, yes. Somehow I'd prefer to avoid that, because it's non-intuitive for my users, but it's certainly a good trick.
                            • 11. Re: Selectable text from an alert dialog?
                              Harbs. Level 6
                              You might want to (optionally) add: d.rom.active = true;
                              Harbs
                              • 12. Re: Selectable text from an alert dialog?
                                Harbs. Level 6
                                I'm not sure why you care to replicate the alert dialog exactly, but you can try:
                                1) Do a screen capture to copy the alert icon (or recreate it yourself in Photoshop), and include it as a source. There's a trick that you can store the image in binary form within the script, and write that to file (if you care).
                                2) Play around with ScriptUIGraphics to color in the background and the scroll bar. (Way more effort than it's worth if you ask me...)
                                Harbs
                                • 13. Re: Selectable text from an alert dialog?
                                  Harbs. Level 6
                                  Also, If you want to replicate the position of the icon, you should set the alignment to "top".
                                  Harbs
                                  • 14. Re: Selectable text from an alert dialog?
                                    Shonkyin Level 3
                                    app.copy();
                                    I know that you finished your new ealert but here is code without inserting and removing text frame.
                                    var hello = 'Hello World!'
                                    if (result == 1)
                                    var myAppleScript = "tell application \"Finder\"\rset the clipboard to \"" + hello +"\"\rend tell";
                                    app.doScript(myAppleScript, ScriptLanguage.applescriptLanguage);
                                    Shonky
                                    • 15. Re: Selectable text from an alert dialog?
                                      Harbs. Level 6
                                      For that matter, you can skip the confirm altogether!
                                      Just run that AS with the text you feed to the standard alert!
                                      Harbs
                                      • 16. Re: Selectable text from an alert dialog?
                                        Shonkyin Level 3
                                        confirm is just becuase user have choice of copy result or not.
                                        Shonky
                                        • 17. Re: Selectable text from an alert dialog?
                                          This doesn't seem to change anything. What am I missing?
                                          Well, I figured if it was worth taking any time to do it, might as well do it "right."
                                          With respect to the icon, the ScriptUI documentation indicates that there are standard built-in resources for icons, and gives examples of what they are named in PhotoShop. But what are they in InDesign? (p.68 of javascript-tools_guide_cs3.pdf):
                                          The scripting environment can define icon resources, which are available to scripts by name. To specify an
                                          icon resource, set a control’s image property to the resource’s JavaScript name, or refer to the resource by
                                          name when creating the control. For example, to create a button with an application-defined icon
                                          resource:
                                          myWin.upBtn = myWin.add ("iconbutton", undefined, "SourceFolderIcon");
                                          Photoshop CS3, for example, defines these icon resources:
                                          Step1Icon
                                          Step2Icon
                                          Step3Icon
                                          Step4Icon
                                          SourceFolderIcon
                                          DestinationFolderIcon
                                          I did play around with ScriptUIGraphics...like I said, I get an error:
                                          d.rom.graphics.backgroundColor = d.rom.graphics.newBrush(d.rom.graphics.BrushType.SOLID_COLOR, [1,0,0,0])
                                          Error: Cannot set backgroundColor property for this element type
                                          I can't even figure out the syntax for setting the foregroundColor:
                                          d.rom.graphics.newPen(d.rom.graphics.PenType.SOLID_COLOR, [1,0,0,1])
                                          Error: Bad argument list
                                          Oh, look! ColorPicker.jsx tells us there's a magic 3rd argument to newPen:
                                          swatchGfx.newPen (swatchGfx.PenType.SOLID_COLOR, this.rgbValue, kSwatchBorderWidth);
                                          Totally undocumented!
                                          Changing the foregroundColor works, but isn't helpful. It was already black, as it should be. I'd like to get rid of the white background...
                                          Shonky: thanks...nothing like the choice between the dubious language choice (embedding Applescript in Javascript) or the reluctance to modify the document's DOM (adding a textFrame). I need to take the religion out of scripting!
                                          • 18. Re: Selectable text from an alert dialog?
                                            Harbs. Level 6
                                            It selects the text, so it's just a matter or Command-C...
                                            Harbs
                                            • 19. Re: Selectable text from an alert dialog?
                                              Shonkyin Level 3
                                              Harbs
                                              Hi Harbs,
                                              Can you please show some sample code for converting image to binary and restoring to image using Indesign Javascript.
                                              Shonky
                                              • 20. Re: Selectable text from an alert dialog?
                                                Andreas Jansson Level 2
                                                Hi John,
                                                If you set scrolling to false, the scrollbar disappears.
                                                {readonly: true, borderless: true, multiline: true, scrolling: false});
                                                Best regards,
                                                AJ
                                                • 21. Re: Selectable text from an alert dialog?
                                                  This thread is almost 18 months old.
                                                  • 22. Re: Selectable text from an alert dialog?
                                                    As I was searching the forum for something else regarding scrollbars, I found this thread - no solution for me, but I could add a simple answer on how to remove the scrollbar.
                                                    The age of the thread doesn't matter to anyone else but you. Even if you don't care any longer (you didn't have to answer at all, to show that), there might be other people looking to solve the same thing, and this forum is for sharing knowledge. I know I would have been happy to find out, had I been looking for this exact thing.
                                                    Please read and respect the "Forum etiquette and and best practices": http://forums.adobe.com/thread/414764
                                                    Best regards,
                                                    Andreas Jansson
                                                    • 23. Re: Selectable text from an alert dialog?
                                                      frederickyocum Level 1
                                                      I for one found the whole thread and your amendment useful. Nearly four years later . .  .
