3 Replies Latest reply on Feb 22, 2010 10:41 AM by pbsum83
    Radio Buttons w/ Multiple Values on a PHP Form
    pbsum83
      I have an Online Registration form with several options that each have their own prices.  I want the form results to show the name of each option the user selects, and the total of all the prices combined.  My question is how can I do that when each radio button only allows you to attach one value?  Is there a way to somehow retrieve the option name and price as two separate values?
      <input name="option" type="radio" value="Cotton - $10" />
      <input name="option" type="radio" value="Suede - $15" />
      <input name="option" type="radio" value="Leather - Black - $20" />
      <input name="option" type="radio" value="Leather - White - $20" />
      For example, if they select 'Leather - Black - $20" I want to be able to retrieve one value of "Leather - Black" and another value of "20.00" (to add to the total price) rather than simply "Leather - Black - $20" in one value.
      Any help would be greatly appreciated!  I've only had to deal with one value for each radio button in the past.
      Thanks!
      Paul
        • 1. Re: Radio Buttons w/ Multiple Values on a PHP Form
          Ben M Adobe Community Professional
          Yes you can do this.  If I were you I would eliminate the space in the value just to eliminate confusion.  Then when you process the variable use the Explode function ( http://php.net/manual/en/function.explode.php ) to separate the values in your string.  So if you eliminate the space your code would look like:
          $_POST['option'] = $option;
          $option = explode ("-",$option);
          print $option[0]; //This would print the material
          print $option[1]; //This would print the price
          The only trick is your first two options don't have a color.  So your arrays would be different.  To offset this I would recommend that you use the same format for all options and make some sort of null value if nothing will be added for one value in the array, ie: color.
          • 2. Re: Radio Buttons w/ Multiple Values on a PHP Form
            pbsum83 Level 1
            Thank you very much!  That definitely helps a lot.
            I also have one more issue pertaining to multiple values with radio buttons.  If i have a setup like below, how would I retrieve not only the category (Senor, Adult, or Youth), but find out whether they chose 'Male' or 'Female'  AND find out the price (for adding to the total)?  Is there a way I can somehow attach hidden values to each radio button for later retrieval?
            Seniors $30:
            Male (radio button)
            Female (radio button)
            Adult $50:
            Male (radio button)
            Youth $40:
            Male (radio button)
            Thanks!
            Paul
            • 3. Re: Radio Buttons w/ Multiple Values on a PHP Form
              pbsum83 Level 1
              Anyone?  Sorry for bumping.  Just didn't want it to get lost in the shuffle.  Hoping to sort it out today if possible. Thanks!
