4 Replies Latest reply on Feb 24, 2010 3:33 PM by mazzocchijohn
    getting AppliedCharacterStyle
    mazzocchijohn
      I have a simple question (on the face of it). I'm writing an ID CS4 script in VB6 which uses grep to perform a search & replace (styling really).
      I need to find every occurrence of pd\+ (in other words, a p followed by any number of digits) and to style the digits with the same characterstyle as the "p".
      What I can't work out is how to interrogate the appliedCharacterStyle applied to the "p".
      My search produces grep objects, which I cast to strings ... from there I can't seem to go any further. If I could nail this, the rest is pretty much done.
      Thanks for any help.
      Cheers
      John
        • 1. Re: getting AppliedCharacterStyle
          function(){return A.apply(null,[this].concat($A(arguments)))}
          Actually, it doesn't, and you shouldn't (in that order).
          The list of results you get with FindGrep is sort of pointer to InDesign Text objects. You can access its contents as a string using the "contents"property, but it seems that´s unnecessary at this point.
          The objects in the FindGrep result are full Text objects, so the items can be interrogated just like you would when working immediately with, for example, a text selection. Therefore,
          alert (yourResultList[0].Characters.item(0).appliedCharacterStyle.name)
          shows the character style name of the first character only of the first found result. This is Javascript notation, by the way, but the idea should be the same.
          • 2. Re: getting AppliedCharacterStyle
            mazzocchijohn Level 1
            Thanks. That didn't work, but ...
            myfounditem.Words.Item(1).Characters.Item(1).AppliedCharacterStyle.Name
            did.
            myfounditem is equiv to your resultList[0], & 1s instead of 0s cos this is VB
            Thanks again.
            J
            • 3. Re: getting AppliedCharacterStyle
              AdobeScripts Level 3
              did.
              If your GREP is "p\d+" (not "pd\+") then your result ALWAYS will be "pXXXX" so you don't need to refer to "first word"
              myFoundItem.AppliedCharacterStyle = myFoundItem.Characters.Item(1).AppliedCharacterStyle
              robin
              www.adobescripts.com
              • 4. Re: getting AppliedCharacterStyle
                thanks for that. I could've sworn that I was getting "Object required" when I wasn't specifying the first word, but I've just tried it and it works.
                Must've been soemthing else ...
                Cheers
                J
