2 Replies Latest reply on Feb 21, 2010 8:04 PM by aliandri
    load RTF file to Text sprite
    aliandri Level 1
      Hi, everyone....
      i try learning lingo on folder macromedia and i found this script :
      on readFile
        -- the file path needs to be the same one you wrote to
        filePath = _movie.path & "demoSaveFile"
        -- create a new instance of the fileIO Xtra
        fileIOInstance = xtra("FileIO").new()
        -- error trap for missing file Xtra
        if not fileIOInstance.objectP then
          _player.alert("File IO Xtra missing")
          exit
        end if
        -- open the file for reading
        fileIOInstance.openFile(filePath, 0)
        -- status is a value returned by the fileIO Xtra reporting the status of the last FileIO command executed.
        -- in this case it's the result of executing "openFile(fileIOInstance, filePath, 0)"
        if fileIOInstance.status() = 0 then
          -- the open was sucessful so read the file and then close it
          fileText = fileIOInstance.readFile()
          fileIOInstance.closeFile()
          -- display the text on stage.
          member("file contents").text = fileText
        else
          -- if there was an error display the error message on stage.
          member("file contents").text = "Error: " & fileIOInstance.error(fileIOInstance.status())
        end if
      end
      it's work if that file it's nothing parameter like inside file RTF but if i load file RTF and all parameter it's load to Text Sprite.....
      Can help me ?
        • 1. Re: load RTF file to Text sprite
          Sean_Wilson Adobe Community Professional
          It's not completely clear what you're asking, but I'll assume (from the title) that you're wanting to load RTF from a file on your HDD into a #text member. Like everything in Director, there's more than one way to skin a cat. The simplest solution is the following, which assumes there's a file name "text.rtf" in the same folder as the Director movie:
          -- attached to a button or similar:
          -- you need a text member in your cast library named "text"
          on mouseUp me
            member("text").filename = "@/text.rtf"
          end
          An alternative is to alter what you posted already (I'll focus just around the lines that need changing, the rest can stay like it is):
              member("file contents").rtf = fileText -- CHANGED HERE
            else
          • 2. Re: load RTF file to Text sprite
            aliandri Level 1
            All It's work...
            but
            i choose simple instruction  like :
            on mouseUp me
            end
            Thank you for your attention.....
