0 Replies Latest reply on Feb 21, 2010 11:09 PM by Superfreak85
    Transparency Settings: OuterGlow Size
    Superfreak85
      Hi there,
      I've got an big problem with my AppleScript for InDesign CS4. I would like; that my script apply some object effect with one click for my selection in my current InDesign Document. Here's my script:
      tell application "Adobe  InDesign CS4"
          set dieBreite to page width of document preferences of active document
          --activate
          tell active document
              set mySelection to selection
              if (count mySelection) is 0 then
                  display dialog "Please select an Object"
              else
                  tell the selection
                      tell transparency settings
                          --set properties of outer glow  settings to {applied:true, blend mode:screen, size:150, effect  color:"Paper", opacity:100, technique:softer}
                          --set properties of  blending settings to {blend mode:normal, opacity:60.0}
                          tell outer glow settings
                              set applied to true
                              --    set size to 0
                              set effect color to "R=255 G=251 B=143"
                              set size to 50.9
                          end tell
                      end tell
                  end tell
              end if
          end tell
      end tell
      The Problem is the size; how can I make it higher than 140 points? I would like to have 150 points. Any ideas?
      Hope you can help me, and sorry for my english.
      Cheers
      TheFreak
