1 Reply Latest reply on Feb 22, 2010 2:28 AM by Matt Le Fevre
    Need to open separate Browser window
    madan_vasa
      hi all, I want to display some data in a separate browser window instead of using popupManager. How do i do that. Also i need to pass parameter to that window, based on that parameter, i ll call the service and get the required data and display that in the datagrid.
        • 1. Re: Need to open separate Browser window
          Matt Le Fevre Level 4
          to open a seperate window, you'd have to use the navigateToURL() function
          to pass data to that window, you'd most likely need something like a GET method, if it's alot of data then you'd probably need to create a temporary file and pass a file reference via the GET method.
          or you could look into swf-swf communication
