1. Re: "View Rulers problem in Action"
bonalymac999 Feb 24, 2010 8:42 AM (in response to bonalymac999)Nobody got any thoughts on this
Colin
2. Re: "View Rulers problem in Action"
Reynolds (Mark) Feb 24, 2010 10:14 AM (in response to bonalymac999)Yes - the way to do this is to use View > New Guide. You can type percentages in here. Will record this way in your Action.
3. Re: "View Rulers problem in Action"
bonalymac999 Feb 24, 2010 10:30 AM (in response to Reynolds (Mark))Hi
Just tried that. It doesn't change the ruler settings tho.
What I want to do is display the ruler then change it to percent. That way selections I make will be based on percents and so the action will be usable on different document sizes.
Your suggestion certainly adds the guide in percent terms, but it leaves the Ruler in whatever it wasa reading prior to that. So selections will be based on exact measurements.
I have managed to do it by setting Edit Preferences, but this changes the settiing for every document. I suppose I could re-set at then end (or just leave it at %)
Colin
4. Re: "View Rulers problem in Action"
Reynolds (Mark) Feb 24, 2010 10:52 AM (in response to bonalymac999)Yes, Preference changes record in Actions also. So you can reset them back to pixels or whatever at the end of your Action.
5. Re: "View Rulers problem in Action"
bonalymac999 Feb 24, 2010 11:06 AM (in response to Reynolds (Mark))Thanks. That works fine now.
