0 Replies Latest reply on Feb 22, 2010 7:25 AM by venkatsyss
    Regarding - Checkboxes
    venkatsyss Level 1
      hi,
      My question is how i get the multiple selected checkbox value in httpservice and database in php.
      The following code shows
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
      layout="absolute" creationComplete="userRequest.send()">
      <mx:HTTPService id="userRequest" method="POST" useProxy="false"
      url="check.php" result="Display(event)">
           <mx:request xmlns="">
               <memid>{uRequest.selectedItem.userid}</memid>
           </mx:request>
      </mx:HTTPService>
      <mx:Script>
           <![CDATA[
               import mx.events.ListEvent;
               import mx.rpc.events.ResultEvent;
               import mx.collections.ArrayCollection;
               import mx.controls.Alert;
               import mx.controls.DataGrid;
               [Bindable]private var arr:ArrayCollection;
               private function Display(event:ResultEvent):void{
                   arr=event.result.users.user;
               private function handleSelect(value:Boolean):void
                       userRequest.lastResult.users.user.source.forEach(
                           function callback(item:*, index:int,
      array:Array):void
                               item.sel = value;
                       userRequest.lastResult.users.user.refresh();
                   private function Update():void{
                       userRequest.send();
      </mx:Script>
      <mx:DataGrid dataProvider="{arr}" id="uRequest"
      itemClick="disp(event)">
      <mx:columns>
      <mx:DataGridColumn>
           <mx:itemRenderer>
           <mx:Component>
               <mx:CheckBox selected="{data.sel}">
              </mx:CheckBox>
           </mx:Component>
      </mx:itemRenderer>
          </mx:DataGridColumn>
          <mx:DataGridColumn headerText="Sl.No" dataField="userid"></
      mx:DataGridColumn>
               <mx:DataGridColumn dataField="username">
               <mx:DataGridColumn dataField="useremail">
               <mx:DataGridColumn dataField="userstate">
          </mx:columns>
      </mx:DataGrid>
      <mx:Button label="CheckAll" click="handleSelect(true)">
      </mx:Button>
      <mx:Button label="Update" click="Update()">
      </mx:Button>
      </mx:Application>
      //My Database Query
      if($_POST['memid']!=''){
              $id=implode(',',$_POST['memid']);
              $ids=substr($id,0,20);
              $ans="update tbl_member set member_lname='example' where member_id
      in($ids)";
               $res=mysql_query($ans);
              $answer="select * from tbl_member";
               $result=mysql_query($answer);
              print "<users>";
              while($row=mysql_fetch_object($result)){
              print "<user>
               <userid>".$row->member_id."</userid>
               <username>".$row->member_fname."</username>
               <useremail>".$row->member_lname."</useremail>
               <userstate>".$row->member_state."</userstate>
               </user>";
              print"</users>";
      Please provide me the solution to solve the problem.
      Thanks and Regards,
      venkat.R
