0 Replies Latest reply on Feb 22, 2010 10:25 AM by Carol L. Frampton
    [svn:fx-4.x] 14331: Last batch of PARB changes.
    Carol L. Frampton Level 2
      Revision: 14331
      Revision: 14331
      Author:   cframpto@adobe.com
      Date:     2010-02-22 10:24:42 -0800 (Mon, 22 Feb 2010)
      Log Message:
      If a component's layoutDirection property is set to null it will inherit the value from its parent.
      For IVisualElement, this means layoutDirection=null is equivalent to setStyle("layoutDirection", undefined)
      QE notes:
      Doc notes: None
      Bugs:
      Reviewed By: Hans
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/IVisualElement.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/primitives/supportClasses/Graph icElement.as
