13 Replies Latest reply on Feb 22, 2010 4:31 PM by Matt Petersen
    URGENT HELP master export setup
    inaksi prod
      Default URGENT HELP master export setup
      I tried to search in the forum before I sent this request and I did not find my answer.
      I am using Production suite CS4, Windows 7. I am trying to figure out whatr is the best export setups (codec) to send to the post captioned place who works with Final cut pro. It is a 45 min documentayy shot on hxp170 that will be broadcasted on APTN channel (standard and HD). I shot 720p 24 fps (native) My files are 1.33 pixel ratio.
      I want the best quality possible regardless of the size of the file.
      Can Avid DNxHD codec work? (I googled and did not find a proper answer)
      Also a problem: I tried to export an MXF version and an uncompressed AVI. I used Sapphire plug ins (cartoon, film scratch, glow etc) and with some export setup, it make some clips slide up or left of the screen!!! Anyone had that before?
      Also: should I export 24 fps or 23.976?
      Thanks a lot.
