1 Reply Latest reply on Feb 22, 2010 2:32 PM by o2p
    Dynamic SWFaddress with XML
    o2p
      Hello,
      I have a problem with SWFAddress.
      I come easily to make use of basic functions but I would push a little thing.
      Regarding access to different sections of the site is how I use it and in case of error address, it redirects to the home:
      #include "com/SWFAddress.as"
      SWFAddress.onChange = function()
      var addr = SWFAddress.getValue();
              navigationPage
      (addr);
              trace
      (addr);
      var title = 'Titre du site';
      var names = SWFAddress.getPathNames();
      for (var i = 0; i < names.length; i++) {
                      title
      += ' | ' + names[i].substr(0,1).toUpperCase() + names[i].substr(1);
      SWFAddress.setTitle(title);
      function navigationPage(pageId){
      if(pageId=="/"){
      SWFAddress.setValue('/accueil/');
      }else if(pageId=="/accueil/"){
                              loadMovie
      ("accueil.swf", "holder_mc");
      }else if(pageId=="/audio/"){
                              loadMovie
      ("audio.swf", "holder_mc");
      }else if(pageId=="/contact/"){
                              loadMovie
      ("contact.swf", "holder_mc");
      }else {
      Where things become more difficult is when I want access to music especially in the "audio"
      I add this bit of code to work around the error address:
      }else if(pageId.substr(1,10)=="audio/?ID="){
                      loadMovie
      For now, no problem.
      Then I go to my audio.fla and I load my xml:
      loadXML = function (loaded) {
      if (loaded) {
                      xmlNode
      = this.firstChild;
                      total
      = xmlNode.childNodes.length;
      Thumb = [];
      Title = [];
      Path = [];
      Desc = [];
                      lecteur
      } else {
                      trace
      ("Erreur de chargement");
      filename
      = ["portfolio.xml"];
      path
      = "xml/";
      i
      = filename.length;
      k
      = Math.floor(Math.random()*i);
      xmlData
      = new XML();
      xmlData
      .ignoreWhite = true;
      xmlData
      .onLoad = loadXML;
      xmlData
      .load(path+filename[k]);
      stop
      lecteur
      = function () {
      for (i=0; i<total; i++) {
      Title[i] = xmlNode.childNodes[i].childNodes[0].firstChild.nodeValue;
      Desc[i] = xmlNode.childNodes[i].childNodes[1].firstChild.nodeValue;
      Path[i] = xmlNode.childNodes[i].childNodes[2].firstChild.nodeValue;
                      menu_mc
      .bttn_mc.duplicateMovieClip("bttn_mc"+i, i);
                      menu_mc
      ["bttn_mc"+i]._y = (menu_mc.bttn_mc._height+1)*i;
                      menu_mc
      ["bttn_mc"+i].txt_mc.titleDisplay.text = Title[i];
      if (i<9) {
                              num
      = "0"+(i+1);
      } else {
                              num
      = i+1;
                      menu_mc
      ["bttn_mc"+i].num_mc.numDisplay.text = num;
                      menu_mc
      ["bttn_mc"+i].ID = i;
              ID
      = 0;
              menu_mc
      .bttn_mc._visible = false;
      And here is the code that launches the music when I click on a button:
      loadTrack = function () {
      this._parent._parent._parent.teste.titleDisplay.autoSize = true;
      this._parent._parent._parent.teste.titleDisplay.htmlText = Title[ID];
      this._parent._parent._parent.teste.titleDesc.autoSize = true;
      this._parent._parent._parent.teste.titleDesc.htmlText = Desc[ID];
              my_sound
      .start();
              my_sound
      .loadSound(Path[ID], true);
              holder_mc
      .gotoAndStop(1);
              holder_mc
      .holder.loadMovie(Thumb[ID]);
              titleDisplay
      .text = Title[ID];
              titleDisplay
      .autoSize = true;
      Then I added the function loadtrack :
      SWFAddress.setValue('/musique/portfolio/?ID=' + Title[ID]);
      //verifier la valeur du SWFAddress
                      trace
      (SWFAddress.getValue());
      It works it gives me in the address bar addresses like:
      http://www.monsite/#/musique/portfolio/?ID=mon_titre_de_musique1
      Now the concern I have is when we go to the address:
      It goes in the "audio" but obviously it does not read the "Music 1"
      Someone would have any idea of how to make this work.
      I hope I was precise enough in my application
      Thank you in advance for your help
      o2p
        • 1. Re: Dynamic SWFaddress with XML
          o2p Level 1
          So I just consider another method.
          Instead of dealing with an address "Title [ID]" should be whether the place the item in the xml, so I could tell him that if that number is smaller than the total, I run reader with this ID number and if it is larger or has nothing to do I leave the default player.
          The trick is to find how ... A little help would not be refused.
          PS: Sorry for my english, I'm French
