1 Reply Latest reply on Feb 23, 2010 6:04 AM by injpix
    Using async in an AIR application?
    injpix Level 3
      After reading this FlexUnit tutorial:
      http://www.adobe.com/devnet/flex/articles/flashbuilder4_tdd.html
      I downloaded the files here:
      http://download.macromedia.com/pub/developer/flashbuilder4_tdd_source.zip
      ...and changed the project, FlexUnit4Examples, to an AIR application via FlashBuilder.  After I did that, it no longer passes all of its asynchronous tests.
      Do asynchronous tests have any issues or limitations with AIR?
        • 1. Re: Using async in an AIR application?
          injpix Level 3
          The problem I had was not related to FlexUnit.  It was the way I was tried to access the file system when it was an AIR application.  I used FileStream instead of what was in the tutorial that worked with a web base application, which was HTTPService.
          Since I am new with unit testing, I assumed that it was the test that was coded wrong.  I suppose I havent trusted my unit tests enough, since it told me that my source code was incorrect.
