0 Replies Latest reply on Feb 22, 2010 3:10 PM by Jason Szeto
    [svn:fx-4.x] 14345: Mirroring bug fixes
    Jason Szeto Level 3
      Revision: 14345
      Revision: 14345
      Author:   jszeto@adobe.com
      Date:     2010-02-22 15:10:45 -0800 (Mon, 22 Feb 2010)
      Log Message:
      Mirroring bug fixes
      http://bugs.adobe.com/jira/browse/SDK-25561 - MX PopUpButton displays popup inconsistently when layoutDirection is set to rtl
      http://bugs.adobe.com/jira/browse/SDK-25560 - MX ColorPicker displays popup inconsistently when layoutDirection is set to rtl
      Translate the position of the popup from the mirrored coordinates to the un-mirrored global coordinates
      http://bugs.adobe.com/jira/browse/SDK-25552 - The Spark CheckBox icon should be mirroring
      Removed setting the icon layoutDirection = ?\226?\128?\156ltr?\226?\128?\157. The icon should follow the mirroring of the component.
      http://bugs.adobe.com/jira/browse/SDK-25484 - MX Slider datatip is incorrectly positioned when layoutDirection is rtl
      Fixed two issues. The dataTip positioning is fixed by translating the position of the popup from the mirrored coordinates to the un-mirrored global coordinates. The second is fixing an issue of reversing the dataTipPosition when ?\226?\128?\156left?\226?\128?\157 or ?\226?\128?\156right?\226?\128?\157 when mirrored.
      QE notes: None
      Doc notes: None
      Bugs: SDK-25561, SDK-25560, SDK-25552, SDK-25484
      Reviewer: Hans
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/PopUpButton.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/sliderClasses/Slider. as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/skins/spark/CheckBoxSkin.mxml
