1 Reply Latest reply on Feb 22, 2010 4:08 PM by Flex harUI
    Rotate / Invert DataGrid - i.e. columns as rows
    stickamw
      Hi All,
          Ok, I've been fighting with this one and  haven't been able to find much out there.  I have a requirement to  create a datagrid who's data is listed as a row instead of a column with  the headers being the first column of the DG and the data returns being  the 2...n columns. For example:
      HostCluster A
      Cluster B
      Date2010-01-022010-01-02
      Devices28623114
      Consumed1124212355
      Available43083195
      Total15550
      15
      I've gotten close to the solution with this:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" initialize="initApp();">
          <mx:Script>
              <![CDATA[
                   var rotated
                   var clusterArray ;
                   private function initApp()  {
                      rotated = new Array();
                      clusterArray = new Array();
                        var objOne:Object = new Object();
                        objOne = {Host:"Cluster A", Date:"2010-02-09", Devices:2862, Consumed:11242, Available:4308, Total:15550};
                        clusterArray[0]=objOne;
                        var objTwo:Object = new Object();
                        objTwo = {Host:"Cluster B", Date:"2010-02-09", Devices:3114, Consumed:12355, Available:3195, Total:15550};
                        clusterArray[1]=objTwo;
                        var j =  0;
                        for (var col in objOne) {
                             rotated[j] = new Object();
                             for (var i =  clusterArray.length - 1; i >=0; i--)
                              rotated[j]["col" + i] = clusterArray[i][col];
                                 rotated[j]["abc"] = col;
                                 j++;
                        dg1.dataProvider=clusterArray;
                        dg2.dataProvider=rotated;
          </mx:Script>
          <mx:DataGrid id="dg1" />
          <mx:DataGrid id="dg2" showHeaders="false"/>
      </mx:Application>
      However, the problem I am running into is that this is arbitrarily ordering the data for me, which I don't want it to do...i.e. the table headers (down the first column) and associated data are ordered:
      Available
      Consumed
      Date
      Devices
      Host
      Total
      So question #1 is what do I need to do to stop the alphabetizing that is happening?
      And question #2 is how can I programmatically invoke a renderer on that first column (using this setup) to shade the "headers"?
      Many thanks in advance!!
      Adrian
