3 Replies Latest reply on Oct 5, 2007 4:01 AM by flip3r
    Flex Build Path : How to really customize output folder ?
    flip3r Level 1
      Hi all,
      I am using this kind of project structure :
      D:\project\src\ : the flex project sources
      D:\project\src\classes\ : the mxml / AS classes
      D:\project\bin\ : the swf output
      My main application is in this path :
      D:\project\src\classes\projectPackage\Main.mxml.
      I configured my Flex Build Path (in the flex project properties) this way :
      - Main source folder : classes
      - Output folder : D:\project\bin
      Unfortunately, the output files are created in these paths :
      D:\project\bin\projectPackage\Main.swf
      D:\project\bin\projectPackage\Main-debug.swf
      D:\project\bin\projectPackage\Main-profile.swf
      Whereas I wanted :
      D:\project\bin\Main.swf
      D:\project\bin\Main-debug.swf
      D:\project\bin\Main-profile.swf
      Would you know if it is possible to configure the real output folder somewhere ?
      Thank you all
      Cheers
      Philippe
        • 1. Flex Build Path : How to really customize output folder ?
          levancho Level 3
          from project properties :
          make :
          Main source folder :D:\project\bin\projectPackage
          then same window on top where it says additional source folders outside of main source folder add src/classes (and/or) src
          that should take care of that problem.
          • 2. Re: Flex Build Path : How to really customize output folder ?
            flip3r Level 1
            Hi levancho,
            Thanks for your answer.
            You probably meant to use src\classes\projectPackage as the Main source folder.
            This is working this way. However, there are some little problems :
            I have this warning : " Source path entry, ' D:\project\src\classes', is a subdirectory of source path entry, ' D:\project\src\classes\projectPackage'." which is strange because it is the second path which is a subdirectory of the first.
            There are conflicts when the compiler tries to resolve the classes within the src\classes\projectPackage directory. For instance, for a class clalled Application located in src\classes\projectPackage\Application.as, it doesn't know how to make a difference between Application and projectPackage.Application.
            Solution : move classes from projectPackage to some sub packages.
            Anyway, if it may not be the perfect solution, it just works, so thank you very much :)
            Regards,
            Philippe
            • 3. Re: Flex Build Path : How to really customize output folder ?
              flip3r Level 1
              Hi levancho, hi all,
              Actually there were too many conflicts with your solution, levancho.
              So I just moved my main application file to the classes directory ( D:\project\src\classes\Main.mxml instead of D:\project\src\classes\projectPackage\Main.mxml) and this is much better this way ! :
              No conflicts, clean build path !
              Thank you very much anyway levancho.
