1 Reply Latest reply on Feb 23, 2010 2:01 AM by quoc_thai
    Scrolling on AdvancedDataGrid
    quoc_thai Level 1
      Hi all,
           I use AdvancedDataGrid to show data to user. I also wrote ItemRenderer called My_Renderer and set it to some ADG columns.
                1. From main mxml component, I used a static arraycollection to store my data called Old_Array.
                2. Inside My_Renderer, at the set data function, I compare current value of columns that I set My_Renderer with old value in Old_Array by get row index number from ADG, such as:
      override public function set data(value:Object):void{
                     super.data = value;
                     if (value != null){
                          currentValue = Number(listData.label);     --> Get new value column.
                          colName = (lisData as AdvancedDataGridListData).dataField; --> Get name of column.
                          rowIndex = (lisData as AdvancedDataGridListData).rowIndex; --> Get row index.
                          oldValue = Number(Old_Array[rowIndex][colName]);     --> Get the old value from static Old_Array
                          if (oldValue != currentValue){
                               bgColor = 0x000000;
                               Old_Array[rowIndex][colName] = currentValue;     --> Set new value to static Old_Array again to compare late.
                          }else{
                               bgColor = 0xFFFFFF;
                3. I override the updateDisplayList function:
      override
      protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void{
        super.updateDisplayList(unscaledWidth, unscaledHeight);
      var g:Graphics = graphics;
      g.clear();
      if (bgColor != 0x000000){
      g.beginFill(bgColor);
      g.drawRect(0, 0, unscaledWidth, unscaledHeight);
      g.endFill();
      else
                          g.clear();
                4. Some things from main mxml component such as:
                <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"  xmlns:myadg="*" layout="absolute" creationComplete="init()">
         private function grdTop_OnScroll(event:ScrollEvent):void
          this.scrollPosition = event.position;
          grMain.verticalScrollPosition = this.scrollPosition;
      private function setData(event:ResultEvent):void{
             var arrResult:Array = event.result as Array;
             arrData = new ArrayCollection(arrResult);
             if (!isFlag){
               isFlag = true;
               Old_Array = arrData;
             grMain.dataProvider = arrData;
             grMain.validateNow();
      <mx:Box height="89">
        <mx:AdvancedDataGrid id="grMain" scroll="grdTop_OnScroll(event)" verticalScrollPolicy="auto" sortExpertMode="true" height="45">
         <mx:groupedColumns>
          <mx:AdvancedDataGridColumn id="Id" headerText="Ma ID" dataField="ID"/>
          <mx:AdvancedDataGridColumn id="Name" headerText="Ten" dataField="NAME"/>
          <mx:AdvancedDataGridColumn id="Value" headerText="Gia tri" dataField="VALUE"/>
         </mx:groupedColumns>
         <mx:rendererProviders>
              <mx:AdvancedDataGridRendererProvider
                      columnIndex="2"
                      columnSpan="1"
                      renderer="My_Renderer"/>
         </mx:rendererProviders>
        </mx:AdvancedDataGrid>
      </mx:Box>
      <mx:RemoteObject id="StockInfo"
                   destination="GenericDestination"
                   source="DBOperation.Operation"
                   showBusyCursor="false"
                   fault="faultHandler(event)" >
           <mx:method name="getTestData" result="setData(event)"/>
      </mx:RemoteObject>
      5. Comparing inside My_Renderer is ok ! I can change background color for cells. My goal at here was success. But when make scrolling on ADG (down or up), drawing background color at some cells were wrong. I bugged my project and know that inside My_Renderer, value of row index not correct at:
      and so, when set new value back to Old_Array wrong array index:
      It's mean when I scrolling on ADG, My_Renderer for some columns not right. I search at google, and know maybe I must extends AdvancedDataGrid and override the scrollVertically function but how I can do this to solve my problem ?
      Thanks.
