2 Replies Latest reply on Feb 23, 2010 3:59 AM by yehuda1233456
    innerHTML equivalent
    yehuda1233456
      hi everyone i need your help (sorry for my english)
      lets say i have this element :
      <mx:VBox id="test" click="insertMxml(event)">
      </mx:VBox>
      And I want to inset mxml inside it dynamically  when the user clicks the element or do something else in the page.
      in javascript i will simply write:
      <script>
          function insertHTML(){
                test.innerHTML = "<myHTML stuff>"
      </script>
      <mx:script>
           public function insertHTML(event:MouseEvent):void{
                what should i do in flex...?
      <mx:/script>
      thank you very much head!
        • 1. Re: innerHTML equivalent
          archemedia Level 4
          You cannot add 'mxml' at runtime, but since mxml is in fact pure AS3, you can. Use AddChild method to do this.
          </mx:VBox>
          private function insertMxml(evt:Event):void
               var myComp:MyCustomComp = new MyCustomComp();
               evt.target.addChild(myComp);
          You can make this as simple or as complex as you want. The simplest way is to make a custom component and add an instance of it to a visual container (in this case a VBox).
          You can remove childs using methods like removeChildAt, removeAllChildren...
          Dany
          • 2. Re: innerHTML equivalent
            yehuda1233456 Level 1
            thank you!
            I really think they should add function that enables adding mxml in run time like DOM, it's very convenient
