4 Replies Latest reply on Feb 23, 2010 12:47 PM by jimmyoneshot
    Writing to 2 Files At The Same Time From an Application
    jimmyoneshot Level 1
      In my application I have a line of code that writes data to a jpeg file like this:-
      var file:File = File.applicationDirectory.resolvePath("assets/images/abcnews.jpg");
      That works fine but I want this data to be written to 2 jpeg files abcnews.jpg AND abcnews2.jpg. I've tried this but it doesn't work:-
      var file:File = File.applicationDirectory.resolvePath("assets/images/abcnews.jpg"; "assets/images/abcnews2.jpg");
      Can anyone please help me modify this code or give me idea to edit it so it writes to both these jpgs? Thanks.
        • 1. Re: Writing to 2 Files At The Same Time From an Application
          archemedia Level 4
          Have you tried using 2 diffrent instances of File?
          var file1:File = File.applicationDirectory.resolvePath("assets/images/abcnews.jpg);
          var file2:File = File.applicationDirectory.resolvePath("assets/images/abcnews2.jpg");
          Dany
          • 2. Re: Writing to 2 Files At The Same Time From an Application
            Hi again Dany. As you know it's part of the code you hepled me out with. I've actually already tried the following which is what you suggested:-
            switch(myhtml.location)
            case "http://abcnews.go.com/":
            var imageBitmapData:BitmapData = ImageSnapshot.captureBitmapData(myhtml) ;
            var s:Object = new Bitmap(imageBitmapData);
            var jpgEncoder:JPEGEncoder = new JPEGEncoder( 60 );
            var ba:ByteArray = jpgEncoder.encode(imageBitmapData);
            var filename:String = "mynewpic";
            var wr:File = new File(file.nativePath);
            var stream:FileStream = new FileStream();
            stream.open( wr, FileMode.WRITE);
            stream.writeBytes ( ba, 0, ba.length );
            stream.close();
            myTilelistAArrayCollection.setItemAt({id:
            "ABC News Item", label:"ABC News Test", icon:"assets/images/abcnews.jpg"}, 0);
            myhtml.location =
            "http://news.bbc.co.uk/";
            break;
            etc
            As you know this takes the bitmap snapshot of the abc news website once it's fully loaded into the html component and saves it as the abcnews.jpg. I know this part works as I've actually deleted the abcnews.jpg and re-ran the app and once it's finished running the jpg has been recreated. It's only the abcnews2.jpg that doesn't seem to be getting created but it should be from the above code as far as I can tell
            • 3. Re: Writing to 2 Files At The Same Time From an Application
              By the way I've also tried to do it by repeating the whole thing again within the same 'case'. It works but seems a bit inpractical considering I have to do this for around 50 sites in my final app so I'll have to repeat this code over and over and over. Like this:-
              stream.close();
              var file:File = File.applicationDirectory.resolvePath("assets/images/abcnews2.jpg");
              stream.close();
              "ABC News Item", label:"ABC News Test", icon:"assets/images/abcnews2.jpg"}, 0);
              myhtml.location =
              break;
              • 4. Re: Writing to 2 Files At The Same Time From an Application
                Actually I now realize that the above code doesn't work. The abcnews1.jpg is being created but not the abcnews2.jpg. It's bizarre as I've basically repated the same code straight below it just for the other jpg and it should work.
