15 Replies Latest reply on Feb 26, 2010 6:29 AM by M.R.Biesheuvel
    Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
    Siebje
      Made a website based on a template, and as so many people, was afterwards struggling with optimizing my titles, descriptions and keywords for SEO. These were/are locked in the head section of the template. I found lots of useful information on the forum to unlock this section, but apparently I am doing something wrong and I can't figure out what. The code error I get is that there is a syntaxis error in the template comment. Also I do see that the color of the code is maybe not the way it should be.
      This is the code I pasted in:
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" >
      <!-- TemplateBeginEditable name=”basisontwerp” -->
      <title>untitled document</title>
      <!-- TemplateEndEditable -->
      <!-- TemplateBeginEditable name="head" -->
      <meta name=”keywords” content=”keywords go here” >
      <meta name=”description” content=”description goes here” >
      <link rel="icon" type="rel/icon" href="images/neroli_logo_mini.png" />
      <link rel="shortcut icon" href="images/neroli_logo_mini.png" />
      <style type="text/css">
      After that there is a whole bunch of stuff regarding two.Col.Elst.Lt.Hdr and style sheets etc. but there is a closing </head> tag just before my header and side bar section.
      Does anybody know what is wrong with my code? I just don't see it ...
      Thanks so much!!!
        • 1. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
          M.R.Biesheuvel Level 3
          Can you upload the template to your server its easier to see if something is wrong...
          • 2. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
            Siebje Level 1
            The site is already live so I am afraid that if I upload the template I have to delete all the rest? Or is there some other way to show you the full code of the template? I attached the dwt hereby maybe this works as well?
            Thanks anyway for your quick response...
            • 3. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
              Couldn't find the attachment, can you give me the error in dutch (Dat is misschien makkelijker dan kan ik dat ook nakijken, ik heb de nederlandstalige versie van Dreamweaver).
              • 4. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                Siebje Level 1
                Hoi,
                Dreamweaver zegt in een mooie combinatie van engels-nederlands het volgende: there is an error at line 5, column 51 (absolute position 296) of "c:\users\...": onjuiste syntaxis in sjablooncommentaar, bijv. ongebalanceerde aanhalingstekens of een missende kenmerkwaarde
                Zal ik anders naar een privé emailadres nogmaals het attachment sturen? Of anders de hele code van de pagina posten?
                Groeten,
                Siebelien
                • 5. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                  Ik zie dat de file attachments niet werken, je kan hem hier publiceren of ff doorsturen naar m'n e-mail adres, kan soms heel vervelend zijn problemen met templates..
                  Grt,
                  • 7. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                    Siebje Level 1
                    Hallo, heb je toevallig al tijd gehad om de code te bekijken? Dank!
                    Helaas, heb het aangepast maar ik krijg dezelfde storingsmelding. Hierbij dan de hele lap code. Het rare is natuurlijk dat de site al live staat en het gewoon doet, dus iets anders dan de toevoeging die ik gedaan heb,kan het niet zijn, lijkt me zo...www.personoil.nl
                    Bedankt voor het bekijken!
                    <!-- body
                    /* Tips voor Elastic-lay-outs 1. Aangezien de algehele grootte van de elastic-lay-outs is gebaseerd op de standaard lettertypegrootte van de gebruiker, hebben deze lay-outs een grotere mate van onvoorspelbaarheid. Bij een juist gebruik zijn ze echter wel toegankelijker voor diegenen die een groter lettertype behoeven omdat de lengte van de regel proportioneel blijft. 2. De grootte van de div-elementen in deze lay-out is gebaseerd op een lettertypegrootte van 100% in het element body. Als u de tekstgrootte algeheel reduceert door middel van font-size: 80% voor het element body of voor #container, dient u niet te vergeten dat de complete lay-out proportioneel kleiner zal worden. Wellicht wilt u de breedtes van de verschillende div-elementen vergroten om dit te compenseren. 3. Als de lettertypegrootte wordt gewijzigd d.m.v. verschillende waarden voor elk element div in plaats van voor het algehele ontwerp (bijv. #sidebar1 krijgt een lettertypegrootte van 70% en #mainContent krijgt een lettertypegrootte van 85%), leidt dit tot proportionele wijziging van de algehele grootte van elk van de div-elementen. Mogelijk wilt u dit aanpassen op basis van uw uiteindelijke lettertypegrootte. */ .twoColElsLtHdr #container .twoColElsLtHdr #header .twoColElsLtHdr #header h1
                    /* Tips voor sidebar1: 1. Vergeet niet dat als u een waarde voor lettertypegrootte voor dit element div instelt, de algehele breedte van het element div dienovereenkomstig wordt aangepast. 2. Aangezien we hier werken met em-waarden, verdient het de voorkeur om voor de zijbalk zelf geen padding (opvulling) te gebruiken. Deze wordt dan voor op standaards gebaseerde browsers toegevoegd aan de breedte, waardoor een nog onbekende daadwerkelijke breedte wordt gemaakt. 3. De ruimte tussen de zijkant van het element div en de elementen erbinnen kan worden gemaakt door het aanbrengen van een linker- en rechtermarge voor dergelijke elementen, zoals wordt aangetoond door de regel ".thrColHybHdr #sidebar1 p". */ .twoColElsLtHdr #sidebar1 .twoColElsLtHdr #sidebar1 h3, .twoColElsLtHdr #sidebar1 p {      margin-left: 10px; /* de linker- en rechtermarge moeten aan elk element worden gegeven dat in de kolommen aan de zijkant wordt geplaatst */      margin-right: 10px; }
                    /* Tips voor mainContent: 1. Als u dit element div voor #mainContent een andere waarde voor lettergrootte geeft dan het element div voor #sidebar1, worden de marges van het element div voor #mainContent gebaseerd op de lettergrootte ervan, terwijl de breedte van het element div voor #sidebar1 zal zijn gebaseerd op de lettergrootte daarvan. Mogelijk wilt u de waarden van deze div-elementen aanpassen. 2. De ruimte tussen mainContent en sidebar1 wordt gemaakt met de linkermarge van het element div voor mainContent. De kolomruimte blijft gehandhaafd, ongeacht de hoeveelheid inhoud die het element div voor sidebar1 bevat. U kunt deze linkermarge verwijderen als u de tekst van het element div voor #mainContent de ruimte van #sidebar1 wilt laten opvullen wanneer de inhoud van #sidebar1 eindigt. 3. Om het wegvallen van het zwevende element te voorkomen, zult u wellicht via uitproberen een schatting van de maximale grootte van de afbeelding of het element moeten bepalen, aangezien deze lay-out is gebaseerd op de lettertypegrootte van de gebruiker in combinatie met de door u ingestelde waarden. Maar als de gebruiker de lettertypegrootte van diens browser echter op kleiner dan normaal heeft ingesteld, is er in het element div voor #mainContent minder ruimte beschikbaar dan u tijdens het uitproberen ziet. 4. In de onderstaande voorwaardelijke opmerking van Internet Explorer wordt de eigenschap zoom gebruikt om "hasLayout" mee te geven aan mainContent. Hierdoor wordt voorkomen dat zich diverse IE-specifieke bugs voordoen. */ .twoColElsLtHdr #mainContent .twoColElsLtHdr #footer .twoColElsLtHdr #footer p
                    /* Miscellaneous classes for reuse */ .fltrt { /* dit exemplaar van class kan worden gebruikt om een element aan de rechterzijde van uw pagina te laten zweven. Het zwevende element moet voorafgaan aan het element dat, op de pagina, naast het zwevende element moet staan. */      float: right;      margin-left: 8px; } .fltlft { /* dit exemplaar van class kan worden gebruikt om een element aan de linkerzijde van uw pagina te laten zweven. */      float: left;      margin-right: 8px; } .clearfloat { /* dit exemplaar van class moet op een element div of break zijn geplaatst en dient het laatste element te zijn vóór de afsluiting van een container (hoofdobject) die op zijn beurt een zwevend object volledig dient te bevatten */      clear:both;     height:0;     font-size: 1px;     line-height: 0px; } .navigatie .twoColElsLtHdr #container #footer table tr td {      font-family: Arial, Helvetica, sans-serif; } -->
                    /* plaats in deze voorwaardelijke opmerking css-correcties voor alle versies van IE */ .twoColElsLtHdr #sidebar1 { padding-top: 30px; } .twoColElsLtHdr #mainContent /* de bovenstaande softwaregebonden eigenschap zoom geeft IE de hasLayout die IE nodig heeft om verschillende bugs te vermijden */
                    <&nbsp>
                    Hoofdinhoud
                    Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Praesent aliquam, justo convallis luctus rutrum, erat nulla fermentum diam, at nonummy quam ante ac quam. Maecenas urna purus, fermentum id, molestie in, commodo porttitor, felis. Nam blandit quam ut lacus.
                    Quisque ornare risus quis ligula. Phasellus tristique purus a augue condimentum adipiscing. Aenean sagittis. Etiam leo pede, rhoncus venenatis, tristique in, vulputate at, odio. Donec et ipsum et sapien vehicula nonummy. Suspendisse potenti. Fusce varius urna id quam. Sed neque mi, varius eget, tincidunt nec, suscipit id, libero. In eget purus. Vestibulum ut nisl. Donec eu mi sed turpis feugiat feugiat. Integer turpis arcu, pellentesque eget, cursus et, fermentum ut, sapien. Fusce metus mi, eleifend sollicitudin, molestie id, varius et, nibh. Donec nec libero.
                    Kop niveau H2
                    Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Praesent aliquam, justo convallis luctus rutrum, erat nulla fermentum diam, at nonummy quam ante ac quam. Maecenas urna purus, fermentum id, molestie in, commodo porttitor, felis. Nam blandit quam ut lacus. Quisque ornare risus quis ligula. Phasellus tristique purus a augue condimentum adipiscing. Aenean sagittis. Etiam leo pede, rhoncus venenatis, tristique in, vulputate at, odio.
                    <!-- var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", ); var MenuBar2 = new Spry.Widget.MenuBar("MenuBar2", ); //-->
                    var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
                    document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
                    try { var pageTracker = gat.getTracker("UA-6508405-2"); pageTracker._trackPageview(); } catch(err) {}</script> </body> </html
                    • 8. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                      Volgens mij gaat er iets helemaal fout ik zie nergens de code staan van je template..
                      • 9. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                        Siebje Level 1
                        He gek; probeer het opnieuw, nu rechtstreeks vanaf de site ipv als reply via de mail:
                        <head>
                        <meta http_equiv="Content_Type" content="text/html" charset=utf-8" />
                        body  {
                        font: 100% Verdana, Arial, Helvetica, sans-serif;
                        background: #666666;
                        margin: 0; /* het is een goede gewoonte om de instellingen voor margin (marge) en padding (opvulling) van het element body op nul in te stellen en daarmee op de standaardinstellingen van de verschillende browsers */
                        padding: 0;
                        text-align: center; /* hiermee centreert u de container (het hoofdobject) in IE 5*-browsers Vervolgens wordt de tekst ingesteld op de standaardinstelling van links uitlijnen in de kiezer #container */
                        color: #000000;
                        .twoColElsLtHdr #container {
                        width: 46em;  /* deze breedte maakt een container (hoofdobject) die past een browservenster van 800 pixels, als de tekst wordt gehandhaafd in de standaard lettertypegroottes van de browser */
                        background: #FFFFFF;
                        margin: 0 auto; /* de automatische marges (d.m.v. auto), in combinatie met een breedte, centreren de pagina */
                        border: 1px solid #000000;
                        text-align: left; /* hiermee wordt de instelling text-align: center voor het element body genegeerd. */
                        .twoColElsLtHdr #header {
                        padding: 0 10px;  /* deze instelling voor padding (opvulling) komt overeen met de uitlijning links van de elementen binnen de div-elementen, die volgen op deze padding. Als een afbeelding wordt gebruikt in de #header in plaats van tekst, wilt u wellicht de padding (opvulling) verwijderen. */
                        background-color: #DDDDDD;
                        background-image: url(../images/achtergrond_kleur_buttons_mouse_over.png);
                        border-top-color: #693;
                        border-right-color: #693;
                        border-bottom-color: #693;
                        border-left-color: #693;
                        border-top-width: thin;
                        border-right-width: thin;
                        border-bottom-width: thin;
                        border-left-width: thin;
                        .twoColElsLtHdr #header h1 {
                        margin: 0; /* door de marge van het laatste element in het element div voor #header op 0 in te stellen voorkomt u het wegvallen van marges – een onverklaarbare ruimte tussen div-elementen. Als om het element div een rand loopt, is dit niet nodig aangezien dit tevens het wegvallen van de marge voorkomt */
                        padding: 10px 0; /* door het gebruik van padding (opvulling) in plaats van een marge (via het element margin) kunt u het element van de randen van het element div vandaan houden */
                        float: left;
                        width: 12em; /* de achtergrondkleur wordt weergegeven over de lengte van de inhoud in de kolom, maar niet verder */
                        padding: 15px 0; /* binnen dit element div maakt de padding (opvulling) aan de onder- en bovenkant de visuele ruimte */
                        background-image: none;
                        background-color: #FFF;
                        margin-right: 10px;
                        .twoColElsLtHdr #mainContent {
                        margin: 0 1.5em 0 13em; /* de rechtermarge kan worden opgegeven in em- of pixelwaarden. Deze marge maakt de ruimte langs de rechterzijde van de pagina. */
                        .twoColElsLtHdr #footer {
                        padding: 0 10px;
                        .twoColElsLtHdr #footer p {
                        margin: 0; /* door de marges van het eerste element in de footer (voettekst) in te stellen op 0 vermijdt u het risico dat de marge wegvalt – een ruimte tussen div-elementen */
                        padding: 10px 0; /* door het gebruik van padding (opvulling) voor dit element maakt u ruimte (op dezelfde manier als door middel van een marge), zonder het probleem van wegvallende marges */
                        float: right;
                        margin-left: 8px;
                        float: left;
                        margin-right: 8px;
                        clear:both;
                            height:0;
                            font-size: 1px;
                            line-height: 0px;
                        .navigatie {
                        color: #9F3;
                        </style><!--[if IE]>
                        .twoColElsLtHdr #mainContent { zoom: 1; padding-top: 15px; }
                        </style>
                        <![endif]-->
                        <script src="../SpryAssets/SpryMenuBar.js" type="text/javascript"></script>
                        function MM_preloadImages() { //v3.0
                          var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
                            var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
                            if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
                        </script>
                        <link href="../personoil.css" rel="stylesheet" type="text/css" />
                        <link href="../SpryAssets/SpryMenuBarVertical.css" rel="stylesheet" type="text/css" />
                        <link href="../SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css" />
                        </head>
                        <body class="twoColElsLtHdr">
                        <div id="container">
                          <div id="header">
                            <table width="100%" border="0">
                              <tr>
                                <td width="25%" height="130"><img src="../images/neroli logo kleiner.gif" alt="" width="97" height="130" align="left" /></td>
                                <td width="49%"><img src="../images/copy heading.png" width="344" height="35" vspace="0" align="middle" /></td>
                                <td width="26%"><img src="../images/neroli logo kleiner.gif" alt="" width="97" height="130" align="right" /></td>
                              </tr>
                            </table>
                          <!-- end #header --></div>
                          <div id="sidebar1">
                            <ul id="MenuBar1" class="MenuBarVertical">
                              <li><a href="../index.html">Personoil</a></li>
                              <li><a href="../waaromolie2.html">Waarom olie van Personoil?</a></li>
                              <li><a class="MenuBarItemSubmenu" href="../ingredienten.html">De natuurlijke ingrediënten</a>
                                <ul>
                                  <li><a href="../basisolien.html">De basisoliën</a></li>
                                  <li><a href="../essentieleolien.html">De essentiële oliën</a></li>
                        </ul>
                              </li>
                              <li><a href="../huidtypes.html">Jouw huidtype</a></li>
                              <li><a href="../gezichtsmassage.html">Gezichtsmassage en andere tips</a></li>
                              <li><a href="../bestellen.php">Advies en bestellen</a></li>
                            </ul>
                        <h3> </h3>
                          <!-- end #sidebar1 --></div>
                          <div id="mainContent">
                            <ul id="MenuBar2" class="MenuBarHorizontal">
                              <li><a href="../contact.html">Contact</a>      </li>
                              <li><a href="../betalen.html">Veilig betalen</a></li>
                              <li><a href="../verzenden.html">Verzending</a>      </li>
                              <li><a href="../voorwaarden.html">Algemene voorwaarden</a></li>
                            </ul>
                            <!-- TemplateBeginEditable name="editregion" -->
                            <&nbsp>
                            <h1> Hoofdinhoud </h1>
                            <p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Praesent aliquam,  justo convallis luctus rutrum, erat nulla fermentum diam, at nonummy quam  ante ac quam. Maecenas urna purus, fermentum id, molestie in, commodo  porttitor, felis. Nam blandit quam ut lacus. </p>
                            <p>Quisque ornare risus quis  ligula. Phasellus tristique purus a augue condimentum adipiscing. Aenean  sagittis. Etiam leo pede, rhoncus venenatis, tristique in, vulputate at,  odio. Donec et ipsum et sapien vehicula nonummy. Suspendisse potenti. Fusce  varius urna id quam. Sed neque mi, varius eget, tincidunt nec, suscipit id,  libero. In eget purus. Vestibulum ut nisl. Donec eu mi sed turpis feugiat  feugiat. Integer turpis arcu, pellentesque eget, cursus et, fermentum ut,  sapien. Fusce metus mi, eleifend sollicitudin, molestie id, varius et, nibh.  Donec nec libero.</p>
                            <h2>Kop niveau H2 </h2>
                            <p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Praesent aliquam,  justo convallis luctus rutrum, erat nulla fermentum diam, at nonummy quam  ante ac quam. Maecenas urna purus, fermentum id, molestie in, commodo  porttitor, felis. Nam blandit quam ut lacus. Quisque ornare risus quis  ligula. Phasellus tristique purus a augue condimentum adipiscing. Aenean  sagittis. Etiam leo pede, rhoncus venenatis, tristique in, vulputate at, odio.</p>
                          <!-- end #mainContent --></div>
                        <!-- Dit wiselement dient onmiddellijk te volgen op het element div voor #mainContent om het element div voor #container te dwingen om alle zwevende elementen van een lager niveau te bevatten --><br class="clearfloat" />
                           <div id="footer">
                             <p> </p>
                          <!-- end #footer --></div>
                        <!-- end #container --></div>
                        var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", {imgRight:"SpryAssets/SpryMenuBarRightHover.gif"});
                        var MenuBar2 = new Spry.Widget.MenuBar("MenuBar2", {imgDown:"../SpryAssets/SpryMenuBarDownHover.gif", imgRight:"../SpryAssets/SpryMenuBarRightHover.gif"});
                        </script>
                        </script>
                        try {
                        var pageTracker = _gat._getTracker("UA-6508405-2");
                        </body>
                        </html>
                        • 10. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                          <head>
                          <meta http_equiv="Content-Type" content="text/html; charset=utf-8" />
                          <!-- TemplateBeginEditable name="basisontwerp" -->
                          <title>Naamloos document </title>
                          <meta name="keywords”" content="keyword1, keyword2" />
                          <meta name="description”" content="Dit is een template document" />
                          body  {
                          padding: 0;
                          color: #000000;
                          float: left;
                          margin-right: 10px;
                          padding: 0 10px;
                          float: right;
                          margin-left: 8px;
                          float: left;
                          margin-right: 8px;
                          clear:both;
                              height:0;
                              font-size: 1px;
                              line-height: 0px;
                          .navigatie {
                          color: #9F3;
                          </script>
                          try {
                          </body>
                          </html>
                          • 11. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                            Ik heb de keywords en de description aangepast en het bewerkbaar gebied opnieuw ingevoerd, bij mij is die nu werkend dus ik hoop dat ie voor jouw nu ook werkend is.
                            Grt,
                            • 12. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                              Siebje Level 1
                              Joepie, het werkt!! Wat goed en fijn.
                              Ik snap alleen niet wat je hebt gedaan: zo te zien is het enige andere dat je een dubbel aanhalingstekens sluiten rondom keywords en description hebt gezet, waarbij de een er dan wat anders uitziet dan de andere...klopt dat en wat is de gedachte hierachter? Zodat ik het tenminste voor een volgende keer zelf zou kunnen bedenken.
                              In ieder geval reuze bedankt!
                              Groeten,
                              Siebelien
                              • 13. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                                Ik heb de meta keywords en content gesloten met /> i.p.v. alleen >.
                                In xml en dus ook xhtml is > gewoon open en pas gesloten met /> en de tags moeten altijd gesloten worden:
                                <tag /> of <tag></tag> is gesloten in xml of xhtml. <tag> is gewoon open
                                Groetjes,
                                • 14. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                                  Siebje Level 1
                                  Volgens mij had ik dat ook in eerste instantie en toch gaf ie die error code. Gek hoor...
                                  En die dubbele aanhalingstekens, wat doen die?
                                  Jij hebt geschreven:
                                  Dus "keywords"", maar dan ziet de 2e " er anders uit; idem bij description; DW accepteert dat dus goed, terwijl ik als leek zou denken dat je dan juist een teken-fout hebt omdat er iets dubbel instaat...
                                  • 15. Re: Added editable regions in order to insert meta tags, but get code error. What did I do wrong?
                                    Oops de dubble aanhalingstekens bij keywords is een tikfoutje, moet er natuurlijk een zijn
